Old 09-27-2009, 11:43 AM   #1
Hawker7
Temp Gauge resistance chart
Does anyone have that chart that showed what the ohm reading should be with various temperatures when measuring from the temp sender?
Hawker7 is offline   Reply With Quote
Old 09-28-2009, 07:18 PM   #2
Hawker7
Re: Temp Gauge resistance chart
Anyone have this? I'm trying to see what my truck is running at. The needle won't move past the first mark on the stock guage even after driving for 30 min. I put a ohm meter on the sender when it was warm and it read .440
Old 09-28-2009, 07:27 PM   #3
JMac11
JMac11's Avatar
Try this article
http://www.lbfun.com/warehouse/tech_...eCF-Thread.pdf
JMac11 is offline   Reply With Quote
Old 09-28-2009, 07:46 PM   #4
JimKshortstep4x4
Re: Try this article
As I recall hot is 180 ohms and cold is 800 ohms.
Our local NAPA has information on the ohm values so you may want to check with them.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
