Old 09-27-2009, 02:30 PM   #1
gopokes
gopokes's Avatar
Lowering block question
I was getting ready to order some 2 inch lowering blocks from cpp and they have a note saying that 2 inch blocks are not "recomended" for 15 inch wheels. Why is that?
gopokes is offline   Reply With Quote
Old 09-27-2009, 03:35 PM   #2
SCOTI
SCOTI's Avatar
Re: Lowering block question
The bottom of the u-bolts & shock plates will be lower than the lip of the wheel. If you have a blow-out while @ speed, there's a definite possibility the u-bolt & shock plate could dig-in to mother earth & ruin a perfectly good truck ('cause that's what will happen if it catches on something).
This is commonly referred to as hanging 'below the scrubline'. 1.5" blocks are about the max w/a 15" wheel. There are many that run 2" & 3" blocks & say it's not an issue; but it can happen. If you run a larger diameter wheel (17's,18's, 20's), the lip of the wheel will be below the u-bolt/shock plate & above the scrub-line.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-27-2009, 03:50 PM   #3
gopokes
gopokes's Avatar
Thanks for the help. I went out and looked at my truck and it doesn't look to me like I can use blocks at all. The bottom of the u-bolts are already pretty close to the bottom of the rim. Does this look normal?
Old 09-27-2009, 06:16 PM   #4
SCOTI
SCOTI's Avatar
That's stock/OE configuration. Blocks can/would go between the truck arm & the pad under the rear housing tube. It would require longer specialty u-bolts (not available @ the local parts house).
You could do 1.5" blocks & 15" rims.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
