09-27-2009, 05:57 PM | #1 |
lmc ss brake line delima
i received my much anticipated ss brake line kit from lmc last thursday, i ordered the two piece front to rear set and the complete master cylinder and front line set basically everything except for the rear axle lines (should have ordered them also, but thats another story). anyway all was going well till i noticed that my new lines are made to go over the crossmember/under motor mounts to what supposed to be a tab on the front of the crossmember on each side (driver and pass) for the ss lines and the rubber lines going to the caliper to pass through. my tabs are on the rear of the crossmember, @#$%, i thought all 71 c10 brake lines were routed this way, to the front am i wrong? plus my line going to the rear seems a bit short it stops about 1' shy of the rear end in the frame? the only other thing is there is a very precisely bent ss line with a 90 degree bend and a 45 degree hook at the end, has anyone else encountered these problems. i need some good detailed picks of 71 lwb base lines and hoses if anyone has any, please help these lines are holding up the great progress ive been making from freshly painted frame to totally assembled frame in 1/2 a day now im stuck!
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
09-27-2009, 06:19 PM | #2 |
Re: lmc ss brake line delima
Can't really help you but I know exactly how you feel. I just ran new lines on my 4wd from inlinetube and they sent absolutely no instructions. I would suggest checking LMC's website as they have semi-detailed pics of 2wd trucks. Or maybe hit a local salvage yard?
09-27-2009, 06:28 PM | #3 | |
I have never found any prebent kit that fits perfect no matter who makes it. If its modified at all the chances are even less. Heck your lucky if it fits perfect |
09-27-2009, 06:38 PM | #4 |
The OEM steel kit I got from Inline tube fit perfect, once I figured out where they needed to be. I would reccomend them to anyone running new lines.
09-27-2009, 07:56 PM | #5 |
i really dont mind the modifying, just wondering more or less if i ordered the correct kit. if i could find the tabs to mount to the crossmember i could just tack weld them in place and be done with it.
09-27-2009, 08:14 PM | #6 |
sorry i had to cut myself short to get the baby, if i could get the tabs to go on the crossmember the front problem would be solved. pictures of the way the lines and caliper hoses are supposed to be run on an 71 c10 lwb would be more help than anything because , and yes, they were not done correctly by the previous owner(s) of the truck much like everything else. or even a diagram of the correct way.
09-27-2009, 08:16 PM | #7 |
They make a great product and one of the best in the industry. However I would not say there stuff fits perfect every time.
09-27-2009, 08:19 PM | #8 | |
I am not sure exactly what the problem is. A pic would help |
09-27-2009, 08:23 PM | #9 |
+1 - My SS kit from I.T. was an absolute nightmare......every piece was wrong...Bad bends & wrong fittings......many bends were not even close...I'll make my own next time!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 09-27-2009 at 08:23 PM. |
09-27-2009, 08:33 PM | #10 |
These are the tabs that I am needing. where the ss hard line connects to the rubber line, if i knew where to purchase a pair of them i would be in buisness
'71 LWB c10-"WORK" in progress 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage Last edited by skeeterbug; 09-27-2009 at 09:12 PM. |
10-29-2009, 06:49 AM | #11 |
i can just fab up my own tab, but the problem is the only fr brake hoses i can find are 11.5" long which is about 2" to short. oriely ap and napa's are the same lenght 11.5" long, anyone else run in to this issue with a '71 with stock disk in front, if so what did u do?
10-29-2009, 10:24 AM | #12 |
Happy to be here
Check for 73-87 brake lines. They should be longer.
