Old 09-28-2009, 04:23 PM   #1
Tony_SS
Tony_SS's Avatar
Unhappy Suspension Woes
So I have the 2" drop springs installed and the height looks the same. Also, this shackle and hanger kit from Summit requires notching the rear support. I wasn't aware of that! I guess thats how all shackle kits are? Anway, since the front sits kinda high, I only did the hangers to lower the rear 2". Will that cause any issues with the pinion angle?
Tony_SS is offline   Reply With Quote
Old 09-28-2009, 06:19 PM   #2
Tony_SS
Tony_SS's Avatar
Re: Suspension Woes
On everyone else's drop springs, did they settle at all? I'm getting about an inch drop from 2" drop springs. Should I expect these to go down in time some?
Old 09-28-2009, 06:27 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Suspension Woes
Did you make sure the top of the front springs are "clocked" correctly to seat in the front crossmember spring pocket?
There is a round groove in the upper spring pocket that the spring sets in.
You also have to remember that these springs are 2" shorter than brand new stock height springs,... not springs that are 23 years old. I'm sure your old springs were sagging a little.
The best bet is to find a truck that has the "look" you like,... and find out what they did to lower it.
The shackle/hanger kit only requires notching if you have a 52" rear leaf spring.
The trucks with 56" rear leaf springs do not require notching the bed rail.
Lowering is an addiction. You will always want to go lower.
Keith
Convert to disc brakes.
Old 09-28-2009, 06:33 PM   #4
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: Suspension Woes
Mine settled a little. But again, the static drop is measured from new stock height. Cut half a coil if you need. And, yes there is a "go lower" bug that bit me a while back. I am low, but I keep thinking..."just another inch."
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-28-2009, 07:11 PM   #5
menace121978
menace121978's Avatar
Re: Suspension Woes
me too buddy, me too...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-28-2009, 07:33 PM   #6
LiveAnimals
LiveAnimals's Avatar
Re: Suspension Woes
Not me 3/4 ftw
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 09-28-2009, 09:53 PM   #7
Tony_SS
Tony_SS's Avatar
Re: Suspension Woes
I figured my old sagging springs made the truck sit lower to begin with... I don't know if the new ones are 'clocked' in. I dont really feel good about dealing with coil springs under pressure so I had a shop swap them out.. I hope they put them in right.
I'll be happy with a 3/4 since this is my driver I dont want to do too low. Kameron, did you use 3" drop springs? I may have to go that route since I dont want spindles to push the wheels out.
Old 10-01-2009, 08:02 PM   #8
northern 85
northern 85's Avatar
Re: Suspension Woes
2 inch ground force front springs 2 inch schackles
Name:  2 inch ground force front springs 2 inch shackles.jpg
northern 85 is offline   Reply With Quote
Old 10-02-2009, 12:10 AM   #9
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: Suspension Woes
i dont think i have ever seen anyone that is happy with a shackle hangeronly set up in the rear, everyone always wants it a lil lower.
staggerd86c-10 is offline   Reply With Quote
Old 10-02-2009, 08:04 PM   #10
northern 85
Re: Suspension Woes
Tony ss how are you doing with the lowering?
Old 10-03-2009, 12:18 AM   #11
LiveAnimals
Re: Suspension Woes
The 73 has 3" springs and the 77 has 3" spindles
I've had plenty of low trucks, its just not practical to me anymore.
Kameron
Old 10-03-2009, 10:25 AM   #12
Tony_SS
Tony_SS's Avatar
Re: Suspension Woes
Well, I'm being picky. The front 2" springs still leave a good 3" of gap between the tires I"m running. Also, one sides sits 1/2" higher than the other up front.
And the rear (used only the hangers so far) is giving me some vibration from the pinion angle being off.
I think I'll go for a 3" drop up front and use the shackles in the back for a 4" drop.
I'm just not sure of how to get a good 3" drop. Kameron, do your 3" drop spindles push your wheels out? Any issues with them? What brand?
Old 10-03-2009, 10:34 AM   #13
LiveAnimals
Re: Suspension Woes
They did seem to push the wheels out a little bit, they are DJM brand, the only issue I had was I had to grind the top of the caliper and spindle to get my 15 in rallie to fit.
Kameron
Old 10-03-2009, 10:39 AM   #14
Tony_SS
Tony_SS's Avatar
Re: Suspension Woes
Hmmm.. Ill take some pics and get everyones feedback before I change anything else..
Old 10-19-2009, 08:43 PM   #15
northern 85
Re: Suspension Woes
Any pics yet?
Old 10-20-2009, 09:03 AM   #16
Tony_SS
Tony_SS's Avatar
Re: Suspension Woes
Sorry..none yet. No time to wash the truck lately or even snap a few pics. I'll see what I can do today though, work permitting.. supposed to be nice weather.
