Old 09-28-2009, 07:16 PM   #1
Hawker7
Body Trim Question
Does all the aftermarket trim have to be bolted/screwed on, or does someone sell some that can be put on with the double sided tape that are used on current trucks/cars?
Hawker7 is offline   Reply With Quote
Old 09-28-2009, 08:27 PM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: Body Trim Question
The stock style trim is designed for clips and screws, I suppose that you could glue it on somehow.
If you're concerned about rust, then use a sealer where all the attaching points are and regularly hose dirt trapped behind the moldings. Also, you could put a strip of black tape or something along the edges that touch the paint.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 09-28-2009, 08:31 PM   #3
Hawker7
I wasn't going to use trim again so I filled all the holes before I painted. Now, I think I have changed my mind and I don't want to drill holes again....
Old 09-28-2009, 08:45 PM   #4
GruntMoanCough
Well, I suppose that you could remove the studs from the molding clips and use two-sided tape on them, don't know if they would be secure enough though.
Just which trim pieces are you referring to?
Old 09-28-2009, 08:47 PM   #5
Hawker7
Upper and lower molding...
Old 09-28-2009, 09:02 PM   #6
superchevy
Got big-block?
superchevy's Avatar
I'm going to use double-sided tape for my upper and lower moldings. Use a good quality tape...3M...get some at your local paint/bodyshop supply shop. SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 09-28-2009, 09:10 PM   #7
highperf4x4
use whatever they put on the front door of my freakin house............
If it were me, I'd drill the holes again. I'm still in the process of taking mine off and it's the original 28 year old stuff and it's not coming off easy.
You might call the people at LMC though. They say that their kits have plastic adhesive clips that replace the original metal clips. I'm not sure if they replaced all of them or not.
highperf4x4 is offline   Reply With Quote
Old 09-28-2009, 10:28 PM   #8
71 super
71 super's Avatar
In 71-72 they used a 3m type clip that used the tape to mount the chrome through the middle portions of the chrome and a couple of clips on the ends. I used all metal clips on my 71 and I am using the stick on type on the upper chrome as it was from the factory, after using it on the bed chrome I thnk I made a mistake by not using it on the other truck as it holds things very well. The venders will have the stick on clips you need.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-28-2009, 11:45 PM   #9
highperf4x4
Thx for the info. I'll be going back with new trim eventually myself.
While we're on the subject, how did you get your old metal clips off. Like the ones bolted to the fenders?
Old 09-29-2009, 07:33 AM   #10
Hawker7
By using the stick on clips I don't have to drill any holes for the top or bottom molding?
