Old 09-28-2009, 07:42 PM   #1
KrazyAz
KrazyAz's Avatar
New exhaust sounds to poppy like glasspacks
Hi 2 all.hopefully someone will have an answer to my problem.I just installed a set of custom built headers. 1.75" 16g tubing and new 2.5" 16g tubing with delta 40 flowmaster mufflers.The exhaust dumps out the sides behind the back wheels on my longbed.At idle it sounds great.Accellerating it begins sounding very poppy like glass packs.The old exhaust with same flowies sound throaty from idle to top speed.Old exhaust exited the rear of truck and was almost straight tube all the way back.The new exhaust has a u bend over axle then a 90 to exit the sides of the truck.Are the bends causing the poppyness?If not then what might it be?thank you in advance for your help.
KrazyAz
KrazyAz is offline   Reply With Quote
Old 09-28-2009, 08:13 PM   #2
cdowns
cdowns's Avatar
Re: New exhaust sounds to poppy like glasspacks
dump the blowmasters and you'll get rid of the garbage can sound
Old 09-28-2009, 08:34 PM   #3
kamikazekyle05
kamikazekyle05's Avatar
mine makes that sound when u first start moving then it sounds mean, i have true dual flows dumped over the axle
kamikazekyle05 is offline   Reply With Quote
Old 09-28-2009, 09:52 PM   #4
heavy70
heavy70's Avatar
I think its the bends in the pipe and added length..
heavy70 is offline   Reply With Quote
Old 09-28-2009, 10:26 PM   #5
airdale94
airdale94's Avatar
Flowmaster use to put a notice of this happening in their instructions. It's a result of unburned fuel igniting in the exhaust. You might try leaning your fuel a tad.
Don't want to lean to much though. Cause other problems.
airdale94 is offline   Reply With Quote
Old 09-28-2009, 10:27 PM   #6
texanidiot25
Eat My Rust
texanidiot25's Avatar
H pipes tend to reduce it.
texanidiot25 is offline   Reply With Quote
Old 09-29-2009, 08:17 AM   #7
dznucks
dznucks's Avatar
yes, i agree, H pipes will help.
i had glasspacks and duals with no crossover and it popped like that until i put on the h-pipe.
dznucks is offline   Reply With Quote
Old 09-30-2009, 06:33 PM   #8
big mike71
big mike71's Avatar
I have flowmasters and a H-pipe and it sound great.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 09-30-2009, 07:22 PM   #9
Chevyman680063
Chevyman680063's Avatar
I agree with what some of the others have said...sounds like you need an H or X-pipe. My friend has Flowmasters on his 87 and before he had an H-pipe installed they did that. It sounds really nice and smooth now.
Chevyman680063 is offline   Reply With Quote
