Old 09-29-2009, 10:10 AM   #1
71stub
71stub's Avatar
1960 V8 Swap Radiator Hose Question
I installed an 83 GMC crossmember in my 1960 short fleet and put a 350/700R4 in the truck. My question is what radiator hose will work on my application. I am using the stock 6 cylinder radiator along with a long water pump setup. I can use a flex hose for the upper but I am wondering if anybody has any done this and knows what they used for a lower. Thanks in advance.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 09-29-2009, 01:14 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1960 V8 Swap Radiator Hose Question
My 64 (stock gm) uses a hard line-metal hose for the upper, can you just get a correct v8 rad hose for the lower from the parts store?
Old 09-29-2009, 01:53 PM   #3
71stub
71stub's Avatar
The 6 cylinder radiator has the upper hose in the center of the radiator and not off to the drivers side like the factory V8 radiator. I am unsure if the lower outlet is in the same location as the V8 radiator and those trucks also came with a short water pump...
Old 09-29-2009, 03:07 PM   #4
jchav62
1962 C-10
jchav62's Avatar
I think you can go to the parts store and ask for a hose for a 1960 with a 283. That's what I do for my '62. It has the upper hose in the center also. The offset radiators didn't come out until 63, I believe. 60-62's are in the center...v8 or 6.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-30-2009, 12:22 AM   #5
Captainfab
60-66 Nut
If you go with an original style upper hose, you will also have to use a straight thermostat housing and not the common angled thermostat housing. You might be able to use an original style lower hose, and just trim it a little to compensate for the long water pump.
Old 09-30-2009, 08:34 AM   #6
71stub
71stub's Avatar
I have the center thermostat housing and the radiator is out of a 62 with a 6 cyl and has the outlet in the center also. A flex hose for the upper will work fine and I will see if the lower will work once its trimmed.
Old 09-30-2009, 11:51 AM   #7
MacAttack
283 Drama Queen
MacAttack's Avatar
That's exactly what I did, Hoser. I went with the Summit (aluminum) swivel thermostat cover and a 70' Monte Carlo upper hose. A small trim and it fit perfectly.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-30-2009, 01:47 PM   #8
cliffy
my 60 has a v8 in there now with a stock lower hose.
my o/l says the truck has a vibration at 65 mph..I said its ok, it goes away at 90.
cliffy is offline   Reply With Quote
