Old 09-29-2009, 10:12 AM   #1
bubba35741
bubba35741's Avatar
Need opinions
Looking at buying this blazer. Owner says it is a low mileage Nevada truck. Says it has no rust ever. It also has saddle tanks. It looks like the torsion boxes were removed. I would like to take top off and drive truck sometimes but never off road. Would this worry you? Also does truck look as solid as advertised? Thanks for the help. Bubba
bubba35741 is offline   Reply With Quote
Old 09-29-2009, 10:36 AM   #2
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Re: Need opinions
Bubba, it is hard to tell from the pictures how solid the Blazer is from the pictures that are provided. If you could get some of the floor board under the matting, the windshield frame where the top part joins the side, and the bed floor from both the top and bottom would be more helpful. These are some of the more common places that rust. As far as the rocker boxes, if you wish to drive with the top off, it is better to have them installed verses the saddle tanks being there. I had a set of tanks like that in my 1970 Blazer and it would flex more then I liked with the top off. Fortunately, There are after market replacement boxes available to put it back to factory.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 09-29-2009, 10:44 AM   #3
lks dcvn
lks dcvn's Avatar
Re: Need opinions
Missing Rocker/Torsion Boxes = no top coming off (safely) and driving around.
I wouldn't do it - that isn't to say that it hasn't been done before.
lks dcvn is offline   Reply With Quote
Old 09-29-2009, 06:18 PM   #4
bigbadchev72
People know me
bigbadchev72's Avatar
Re: Need opinions
SAme thing here, po put in saddle tanks in mine. I have been wheeling mine without rockerboxes and no ill effects yet, hardtop still bolts on fine and door gaps are acceptable, not perfect, but not bad at all
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
