Old 09-29-2009, 03:11 PM   #1
jd4300fel
jd4300fel's Avatar
custom heater
Has anybody made a custom heater for our trucks, I live in california so i don't
need a massive system for heat and don't want AC. I was thinking of using bits and peaces of the original unit. I have filled in all the holes on the fire wall
for the factory setup.
Mike
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
Old 09-29-2009, 04:06 PM   #2
mclairmo
Re: custom heater
I think I've seen small units made for the hot rods and kit cars that could be used. Check out Southern Rods or similar.
mclairmo is offline   Reply With Quote
Old 09-29-2009, 04:17 PM   #3
6772owner
Gearhead
6772owner's Avatar
Re: custom heater
Flex-A-Lite makes a nice little street rod heater that I was thinking about using for mine.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 09-29-2009, 07:31 PM   #4
diggertodd
diggertodd
diggertodd's Avatar
Re: custom heater
I used the flex-a-lite, tucked up nicely behind the glovebox and firewall
diggertodd is offline   Reply With Quote
Old 09-30-2009, 09:11 AM   #5
6772owner
Gearhead
6772owner's Avatar
Re: custom heater
Hey diggertodd, do you have any pics of the install?? I would be curious to see how it fit and how you attached it to the dash/firewall.
Old 09-30-2009, 09:45 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: custom heater
AGM at www.acdelete.com has a heater system that can be used as an A/C delete setup but uses less space than the stock unit for a clean look. They say the OEM A/C can be reinstalled, if you like. I am not replacing my OEM air unit, but will go with an aftermarket unit, maybe doing heat/defrost only 'cause I like driving with the windows down so I can hear the exhaust echo off of the walls and windows when I drive....
Member Nr. 2770
