![]() Join Date: Nov 2002
what are these and special promotions pkg on spid ?
looked at a 72 chevy 1/2t and was wondering what these things on the frame are in the engine bay. But it also had a tilt column and a good inner grille
Moderator
![]() Join Date: May 2007
Re: what are these
Heat shield in the engine compartment on the frame rail.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: what are these
things on the frame are for redirecting the air flow back and down under the cab. my 2cents
Trueman |
Back in the sticks
Re: what are these
Doesn't look too bad, either way. Is it running? Engine doesn't look like it.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Re: what are these
nuts bolts and washers..........
Re: what are these
Wasn't there a discusion on some cable thing that keeps the motor from flopping over when the motormount breaks?
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Re: what are these
I'm still trying to figure out what we're looking for. The only thing I see on the frame that shouldn't be there is spark plug wires.
Old Skool Club
![]() Join Date: Jun 2001
Re: what are these
My truck has the recall "fix" on the drivers' side. I found out on here that it is what was used with the cable to keep the engine from falling when/if a motor mount broke. Here's the recall letter, too. Don't know if the "guard" over the motor mount is there for that recall but the letter may help clarify. That shield at first seems to be related to the motor mount, but a closer look says (to me) that it is not attached to the mount. My eyesight may be at fault, if it is.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 09-29-2009 at 11:08 PM. |
Moderator
Re: what are these
The guard over the motor mount is a heat shield, I have the same one on my truck. I believe they came on trucks with a small block engine.
Re: what are these
Nice truck, junk the old engine and get a LS vortec, or better find a new wrecked truck for a parts truck and use everything, Chevys are pretty simple to work on of u got a donor vehicle.
1970 Chevy C10 Short Stepside 4.3L LT 1965 Shelby Cobra AC 427 Comp Car 1965 Sunbeam Tiger 305 1984 Dodge D150 5.9L Magnum 1995 Dodge 3500 V10 1991 Ford 250 460 |
"Trucks with Class"
![]() Join Date: Jul 2000
Re: what are these
That's a 72 "Highlander" package. Those odd pieces are heat shields...not sure what they are shielding.
Re: what are these
Aren't there plastic rivets in the steering shaft holding it together? Maybe the heat shield is to prevent the exhaust heat from melting them? Maybe brake lines?
