86 C10 in the Works, Porterbuilt Questions...
Let me say, I have lurked on the forum for a couple of years, researching and gathering GREAT info.
Story so far: The truck is an 86 2 wheel drive, short bed. I intend to install Porterbuilt dropmembers front and rear. Plan on laying rockers after I cut / roll the pinch weld. I am torn between running 22's all around or going with a 20/22 combo. But before I get too carried away, I have a few questions: 1: When it comes to being able to lay flat on the rocker panels, is there a body drop needed after installing Porterbuilts dropmembers front and back, or does the body of the truck sit lower than the frame rails? (don't have access to truck so I can't see for myself). 2: I've seen trucks on here running 20's or 22's up front but most of them have the heater box out and smoothed the firewall. I have also seen the term 86'ing. Is the AC / heater box different on 86-87 trucks? If so, is it safe to assume I could run the factory AC with such a large diameter tire? 3: With Porterbuilt's front dropmember, can I run different A-arms other than ART's? I would like to run Suicide Doors or Porterbuilt's arms. Nothing against ART, but the ART arms I have on my bagged S-10 pop and creak like crazy! I've greased and greased, but it only helps temporarily. Plus I like the design of the crosshafts better than ART's. SD / Porter crosshaft ends are tapped while ART's are threaded requiring a jam nut (which constantly needs to be tightened). I know it's annoying to read all these questions, but any advise is greatly appreciated. I've researched for a while, but I've not benn able to find complete answers. Thanks for the help! ![]() |
Texas Big Wig
Re: 86 C10 in the Works, Porterbuilt Questions...
I am in no way the expert on this subject, but here goes what I know
Dont remember on 73-87s but Im pretty sure you would still need a body drop to lay rocker (could be wrong) As for the HVAC, I dont really know, cuz Ive never lowered a square body that much, but I have a feeling since its on the outside of the firewall, you're gonna have to shave it And from what I have read I believe you can use just about any control arms on a PB DM even stock ones But if you PM them, they can tell you all the specs you need Last edited by Spray-Bomb; 09-29-2009 at 07:51 PM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Call Nate Porter at Porterbuilt Street Rods,... or PM him on here.
He can answer all your questions. Super nice guy. He will call you and talk to you in person about all your concerns. His number is: 480-326-6303 http://porterbuiltstreetrods.com/ And,... go with the PB a-arms. You won't be sorry.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-29-2009 at 07:59 PM. |
I will answer all your questions a little later on this evening!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
67GMC Slammed
Nathan is a super cool guy, he will spend alot of time on the phone with you for the most simple of things and answer all your questions.
#6 | |
The Dropmembers will get the frame-rails to the pavement, but the pinch-weld will still be between .5" and 1" from the ground (usually depends on how new the body mounts are). So, if you want to lay the rockers on the ground, a body drop is in your future. 2: I've seen trucks on here running 20's or 22's up front but most of them have the heater box out and smoothed the firewall. I have also seen the term 86'ing. Is the AC / heater box different on 86-87 trucks? If so, is it safe to assume I could run the factory AC with such a large diameter tire? The term "86'ing" means "to remove". (I had never heard the term until I started making friends in Texas ![]() 3: With Porterbuilt's front dropmember, can I run different A-arms other than ART's? I would like to run Suicide Doors or Porterbuilt's arms. Nothing against ART, but the ART arms I have on my bagged S-10 pop and creak like crazy! I've greased and greased, but it only helps temporarily. Plus I like the design of the crosshafts better than ART's. SD / Porter crosshaft ends are tapped while ART's are threaded requiring a jam nut (which constantly needs to be tightened). The obvious choice of control arms are the PB arms! Our bushings will never make noise... they are a machined delrin. No pressing to worry about either. The new Dropmember also has a revised lower control arm mount: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
I truly appreciate the great info.
Porterbuilt, your arms look sweet! I love the idea of the delrin bushings. BTW, after seeing many of your posts thru the years, it's easy to figure out the way you conduct your business. That alone has sold me on buying Porterbuilt products (not to mention the beautiful welds). Anyways, I have a couple of questions concerning a bodydrop: If I want to drop the body 1" or so, can I just lower all the body mounts on the frame rails and lower the frame horns at the front of the truck? I'm not sure how much room there is between the top of the frame and the floorboard of the truck. I have also read that another option is to cut the bottom of the frame rails to make the frame profile smaller, essentially getting the same results without doing an actual bodydrop. This idea seemed like a stretch, but I wanted to throw that out there to get some feedback. Thanks yet again! ![]()
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ! My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342 My 2013 Camaro 1LE: https://www.youtube.com/channel/UCxa...wL5d6RnmfdJa1A 86 C10 "Build Thread”: http://67-72chevytrucks.com/vboard/s...d.php?t=668777
Happy to be here
![]() Join Date: Mar 2000
You can lower the body mounts to gain about 1" of drop. You can also section the bottom of the frame under the cab. This won't gain anything until you get the rest done.
86 C10
^^^funny LOL
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold ![]() |
Thanks for the info. Lowering the body mounts and sectioning the frame seems like the easiest route to go. Making a new transmission hump won't be an issue at all. Will I have to make a driveshaft tunnel as well?
