Old 09-29-2009, 08:51 PM   #1
WA1KPD
WA1KPD's Avatar
GMC 150 Tool Locations & Spare Tire?
Good evening
I am a newbie to this having just purchased a 1950 GMC 150 that is in real nice shape. I bought it on line and had it shipped 1200 miles or so. So I have little information
I am still learning my way around it and have some questions.
I read the Chevy manual on line and it says the tool kit and jack were stored under the seat in those models years. However my GMC manual makes no such mention. In addition the seat bottom does not seem to come up.
I would like to mount the spare on the side. Is there a supplier who makes that bracket?
Thanks for your help.
Carl
Carl
WA1KPD is offline   Reply With Quote
Old 09-29-2009, 11:22 PM   #2
NONHOG
NONHOG's Avatar
Re: GMC 150 Tool Locations & Spare Tire?
Looks real good Carl, more pics ! Wish I could help you but I too am a NEWB to the AD trucks. Just brought home a 49 GMC Panel (rough)
good luck to you !
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 09-30-2009, 12:08 AM   #3
solidaxel
solidaxel's Avatar
Welcome from the SW desert of Arizona.
I think your seat bottom will move back by forcing it a bit to the rear (aprox 1") and lifting it up from the front you should be able to gain acces to the underside for a nice storage area. This seat is like a rear seat in a sedan, push it back and lift it up in the front. That is how I gain access in my GMC. As for the spare tire carrier my truck had a drivers fender that was carved out to set the tire above the running board and there was a bracket bolted to the bed side. There is also a under bed (rear) spare tire carrier that is bolted to the frame behind the axle. I will try and take a pic of this tomorrow
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-03-2009, 03:02 PM   #4
WA1KPD
WA1KPD's Avatar
Hi Nonhog and solidaxel
Thanks for the advice. I cant get that seat to budge. Also fine on the wheel. I see I need that push-in on the fender. Too bad, I think the side mount are cool. Unfortunately as nice as the rebuild was on mt truck I guess the tire rack did not make it.
Oh well
Non
Old 10-03-2009, 04:52 PM   #5
63 & 64 Bowties
and a few others
Welcome to the board Carl. Nice truck you've got there.
So, what are your plans? Are you leaving it stock?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 10-03-2009, 05:55 PM   #6
sweet70beast
sweet70beast's Avatar
Do you need the cut out on a 3/4 ton? My 1/2 ton has one on both sides but with the extra space in front of the rear fender on a long box will one fit with out the cutout?
If interested I do have one that I believe came off of a 3/4 ton because the bolts are in a bigger circle than my 1/2 ton spare mounts are. The 3/4 ton mount is not quite and deep as the 1/2 tons.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 10-04-2009, 08:59 AM   #7
1956cameo
1956cameo's Avatar
Your truck bieng a 3/4 ton changes things on the spare tire carrier. I am almost positive that the 3/4 ton trucks did not need the indented fender. You should be able to add a side mount spare without changing rear fenders.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 10-04-2009, 02:27 PM   #8
WA1KPD
WA1KPD's Avatar
Thanks Bill
Plans now are to keep her stock.
But you know a little better gearing for highway use would make iy more usefull. But if I am going to do that the brakes should be upgraded to disc and the steering changed. AC would be nice too......
Just kidding, since the restorer did it up pretty naturally I think I will keep it like that
Carl
Old 10-06-2009, 08:55 PM   #9
sweet70beast
I went out and took some pics of the mounts that I have. The one on the left is one that I took off of a half ton the other one I found in a shed so I'm guessing it's a 3/4 ton because of the differences between the two.
[IMG][/IMG]
This pic shows the difference in the hight.
[IMG][/IMG]
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 10-06-2009, 08:58 PM   #10
sweet70beast
This is the 3/4 ton mount
[IMG][/IMG]
This is the 1/2 ton mount
[IMG][/IMG]
Here's the bracket I sent you the PM about.
[IMG][/IMG]
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
