Old 09-29-2009, 09:58 PM   #1
jojo
printing is my trade
jojo's Avatar
Too many leaks to keep up with
All in the same month
1. radiator inlet for trans cooler < fixed (thank you jb weld)
2. radiator connection from the heater core < fixed (thank you jb weld)
3. heater core leaking bad < fixed by capping off at the intake and radiator and will replace heater core at some point
4. fuel pump connection from tank to fuel pump < fixed
5. fuel pump connection from fuel pump to carb < fixed (I think) < replaced fuel pump
6. I need ya'lls help on this one:
I'm getting what appears to be fuel (it smells a little like fuel) splashed on the passenger side inner fender. I can't seam to isolate where the leak is coming from. How's the fuel getting all the way up there?
Also my new fuel pump has a return line that I just capped off, is there any problem with that?
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 09-30-2009, 12:01 AM   #2
westofb
I really hate wet sanding!
westofb's Avatar
Re: Too many leaks to keep up with
You could just toss a lit match to it to know for sure if it is gas or not...lol.
westofb is offline   Reply With Quote
Old 09-30-2009, 12:15 AM   #3
jojo
jojo's Avatar
Man I wish I thought of that one first! Hold On, I'll Be Right Back....
Actually, I tasted it and it tastes a lot like chicken.
Old 09-30-2009, 08:23 AM   #4
cdowns
cdowns's Avatar
i'd say a bad connection at fuel pump and gas beig blown back by rad fan
Old 09-30-2009, 12:22 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I don't think I'd be wasting any time finding the source, either. It may be that the match that someone else mentioned is one that ignites the fuel while your driving.....not a good event, unless it's chicken.
Member Nr. 2770
Old 09-30-2009, 12:25 PM   #6
hayhauler71
hayhauler71's Avatar
My guess is the fuel pump. Run engine and check the lower part of fuel pump leaking.
hayhauler71 is offline   Reply With Quote
Old 09-30-2009, 12:28 PM   #7
69GMCLonghorn
69GMCLonghorn's Avatar
I HATE LEAKS! Speaking of which, I need to go take one...
69GMCLonghorn is offline   Reply With Quote
Old 09-30-2009, 03:16 PM   #8
Jayss109
Active Member
Jayss109's Avatar
How about the charcoal canister? That still in there?
Cadillac Powered
Jayss109 is offline   Reply With Quote
