09-29-2009, 10:59 PM | #1 |
Wheelin' and Dealin'
anybody running these headers with a sbc
http://www.summitracing.com/parts/HE...9/?image=large
Hedman Hedders 68609 Chevy 1967-81, Camaro, Small Block
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears 1BADD65 my build thread: http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
10-01-2009, 12:14 AM | #2 |
60-66 Nut
Re: anybody running these headers with a sbc
I can't say for certain on those, but considering they are Camaro headers, there may be fitment issues with installing them in a truck. If you're concerned with ground clearance take a look at Hedman's #69230. They are intended for a truck but from the installed pics I've seen they don't hang below the frame much if any.
10-01-2009, 12:38 AM | #3 |
Wide n'Low
I am pretty sure it makes no difference in answering your question, but I tried to run them on my 78, and the passenger side interfered with the firewall..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
10-02-2009, 12:39 PM | #4 |
Those look similar to the generics that are sold on ebay for chevells. The first tube on the drivers side hits the motor mount tower if using factory towers. If your handy with a welder you can make the tower work. The passenger side is close to the frame rail but does clear.
