Old 09-30-2009, 01:07 AM   #1
Ackattack
Ackattack's Avatar
Brothers One piece window question
I worked on installing my one piece windows tonight. (very difficult to do with no directions )
Anyways, I was looking at what I have, and it seems I'm missing a few pieces. It seems I am missing the seal for the widow that goes up the back side of the glass, across the top, and then angled down to the "triangle". Is it supposed to come with this?
The only parts I have left is a piece of felt (is that for the front channel? and the inner and outer scrapper/seals.
Ackattack is offline   Reply With Quote
Old 09-30-2009, 12:19 PM   #2
Custom 68
Custom 68's Avatar
Re: Brothers One piece window question
Humm, I was pretty sure mine came with all that as it is different than the "stock" ones. I can scan you a copy of my directions if you cant get some from brothers site.
I had one of the outer rubber pieces miscut and they were very quick to get me a new piece. They are good to work with. Sounds like you are missing quite a bit, mine cam in a box with individual "compartments" cut in the foam so everything had a place. Sounds odd.
You didnt do like I have done in the past and "put it in a safe place" did you
good luck
Dave
let me know on the instructions.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-30-2009, 12:33 PM   #3
Ackattack
Ackattack's Avatar
Well I think I have it all installed except for the window channel liner.
I test fitted and iinstalled it all before I sent my truck to get painted, and this apparently misplaced the channel liners. Guess I'll keep looking or give Brothers a call.
