Old 09-30-2009, 01:44 AM   #1
420am
420am's Avatar
Free '72 LWB Steel Floor Bed (South KC)
Rust on the inside of the bed pretty bad. Wheel wells are toast as well. There is a lot of straight steel still though. I've stripped it to bare metal for the most part. I only got so far before I decided it would be harder to patch it up than it would be if I started with something in better shape. It has a decent header panel, I'll even throw in the wheel tubs.
Only catch is you have to help me and a friend move a wood bed to get to this one. I also slaughtered the floor because I was too lazy to get under the truck to take the bolts out. I was thinking it was scrapper bound at that point. I imagine whoever takes it will cut it up anyways.
Before I started sanding.
Some of the holes on the inside of the bedsides.
The plan was to give away for scrap. But, if someone here can use it I thought it's best to give it back to you guys.
PM me if you're interested. If you're not local this bed is likely not worth your hassle.
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 09-30-2009, 12:36 PM   #2
420am
420am's Avatar
Re: Free '72 LWB Steel Floor Bed (South KC)
Worst case scenario.. it's what 500lbs or so of scrap steel for free!
Old 09-30-2009, 10:14 PM   #3
420am
420am's Avatar
On to Craigslist it goes.
