Old 09-30-2009, 07:45 AM   #1
Hart_Rod
Hart_Rod's Avatar
Power steering pulley questions...
Does anyone know if the pulley on the BB remote reservoir p/s pump is the same as the small block p/s pulley? Or maybe a better question, does anyone have a pulley for a BB remote reservoir? I shipped one to Camtoys and it got damaged enroute and I would like to find a replacement for him.
R/
Hart_Rod is offline   Reply With Quote
Old 09-30-2009, 10:38 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Power steering pulley questions...
ttt
Old 09-30-2009, 12:34 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Have him get the part number off of it. You may be able to still get one from GM. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-30-2009, 01:16 PM   #4
mplex2000
mplex2000's Avatar
Speaking of power steering...
I made the jump to big block. I already had the rebuilt internal reservoir pump for the small block. I assume this will work with the big block?
The big block came with a remote reservoir pump, bracket and pulley...it'd be nice if I could use the pulley and bracket with my regular pump, anybody know?
Sorry for the little threadjack there Hart_Rod, but it's related
mplex2000 is offline   Reply With Quote
Old 09-30-2009, 02:36 PM   #5
mrh33916
Project '67 454
mrh33916's Avatar
The brackets from a remote reservoir big block pump will bolt right up to a regular pump. The bolt patterns are the same. I converted one from a '86 Burb.
mrh33916 is offline   Reply With Quote
Old 10-01-2009, 04:28 PM   #6
68Stepbed
68Stepbed's Avatar
I'm pretty sure the pulleys and pumps are the same. The only differences are the bracketry system used to mount and align them.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-01-2009, 09:20 PM   #7
Classic Bowties
Always on the hunt...
Originally Posted by Hart_Rod View Post
Does anyone know if the pulley on the BB remote reservoir p/s pump is the same as the small block p/s pulley? Or maybe a better question, does anyone have a pulley for a BB remote reservoir? I shipped one to Camtoys and it got damaged enroute and I would like to find a replacement for him. R/
The 68-72 bbc truck ps pump pulley is P/N 3925537 and it can be found on some sb's and I have also came across a couple I-6's with ps using this pulley. Unlike the many diff. setups/offsets that the sb used, the bbc swp remote fill setup only used this 5537 pump pulley which was driven by the 5525 add on outer crank pulley.
The big block came with a remote reservoir pump, bracket and pulley...it'd be nice if I could use the pulley and bracket with my regular pump, anybody know?Sorry for the little threadjack there Hart_Rod, but it's related
The truck bbc remote res/fill is needed due to there being zero clearance between the ps pump and alternator when using the truck bbc swp brackets, all swp setups place the alt on the drivers side.
The bbc swp remote res./fill pumps & brackets are totaly different when compared the sb setup, the crank and wp pulleys are also bbc/sbc specific.
Classic Bowties is offline   Reply With Quote
Old 10-01-2009, 10:00 PM   #8
Hart_Rod
Hart_Rod's Avatar
CB thanks for the info. Do you have one of the BB pulleys, if so how much?
Rob
Old 01-11-2010, 07:47 PM   #9
trebeck
trebeck's Avatar
If you haven't located one yet, I have one I could part with.
trebeck is offline   Reply With Quote
