![]() Join Date: Jul 2001
Can some one hopefully post some pics of an original, unmolested oil filler extention tube on a 350 V-8 motor. I have the stock filler tube extention and hopefully the correct valve cover for driver's side with disc brakes and vacumn boost assist. Valve cover has one 1 1/4" hole, smooth, round with no twist in lug notches for oil cap. It is used with a rubber grommet for the filler tube and a smaller one for the driver's side PVC. What about the passenger side? I know it needs the one small hole for the tube routed up through the breather. Is there also a larger hole for a push-in rubber based breather cap? My truck does not have original 350 motor but being 4x4 like the idea of not having to stretch so far to put in a quart of oil. Thanks for all replies and in-put.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Anybody with a pic or original set-up info?
newly minted old timer
here are a few picts.. hope you can see the oil filler
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
another
last one.. can you see it? has the orange cap on it
Thanks for the picture of the engine compartment. Looks so much nicer and cleaner than mine. I need to do a lot of clean up, mostly the engine itself. Never paint a engine black, always looks dirty. I can pick out the left side filler and the PCV, also the air cleaner breather tube on the passenger side. Is there another breather cap or oil plug under/behind the a/c compressor? Can't tell for sure. Thanks for posting the pic.
ya there is stuff on that side. there is a 2nd oil filler plug in the front, then on the back there is a hose that goes to the spacer on the carb.. here let me go take a pict
here ya go
one more
Thanks for the pictures. It clears up a few questions for me. I now have one valve cover and need to find another one to be in buisiness. Thanks again for the assistance.
"Ochre Ogre"
I know I have a valve cover with just the single vent hole if that is the one you need. I have seen them like mtdave2's with and without the oil plug on the passenger side.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
