Exhuast routing question?
I would like to have my exhuast go from the Y pipe into the converter (at the original location) then right into a muffler, then have it exit right before the driver tire (only on the driver side).
Does anyone have it this way now? I think I should keep that cat in the stock position to make it work correctly, right? How far away does the muffler need to be from the cat? If its too close to the cat will one of thm get damaged? Just so you understand right after the muffler I want to get a turn down pipe and point it out, instead of down. It should still be reachable by emissions testing personal. And should cost alot less then running duals.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
You get what you pay for
![]() Join Date: Dec 1999
Eddie,
it will sound like crap right behind your head. I would put the muffler as far as I could from the cat, because of the heat these things put off. A freeflow cat will kill a muffler in a hurry. I know this for sure. I completely totated a Dynomax Super Turbo. I would run at least a single in, dual out muffler and exit at the back. What I did was use a Flowmaster y-collector and ran off the cat with dual 2.5" pipes to the back with two Hooker Aerochambers.
Mike 1985 Chevy C-10 |
not what I wanted to hear Mike
![]() Can you post a few pictures of your setup from underneath? What if I had the pipe or pipes come out behind the tire, how would that be for sound? Any better? or does the placement of the muffler play a huge role in sound? What makes a bigger difference the placement of the muffler or the pipe exit placement? Thanks!
driving is in my blood
Eddie, I have ramhorns into dual 2.5", with catco high flow 2.5" vertors going almost strait into 2.5" flow 40series, then exiting right before the rear wheels on each side. The mufflers are tilted to fit, which I need to fix before I lower it. Other then that, it is all a little compact but fits without problems. As long as you dont get a glasspack muffler you'll be fine. Ones like flowmaster have nothing to burn out.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
I'm running mine like he wanted....but i have no muffler....the pipe rotted right before the muffler and cracked in half so I cut it off and put two 2 1/2'' 45degree elbows together and dump it out right infront of the driver's side rear tire....it sounds alright (loud) but the resonance inside the cab is ludicrisly loud especially at WOT.......but at least you know i'm coming if your infront of me....or 4 blocks away for that matter...hehe
Paul D. '78 C20 Scottsdale 350ci 3 speed with granny gear 14 bolt rearend My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian. |
Eddie,
what Tom says is true, about the burning out. The Super Turbo are fiberglass lined and it toasted this fiberglass so bad it busted the seam where the muffler was joined together. I've never seen anything like it. I would at least have 2 feet or so between the cat and muffler, more the better. As far as what it will sound like, it has the most to do with muffler type and pipe size. What I have is my Edelbrock TES headers, with the y-pipe of course. The y-pipe comes with an adapter pipe to adapt it from 3" (what the main y-pipe ends with), to the 2-1/4" tailpipe, or stock cat size. So left the adapter off and had a piece of 3" pipe go to my 3" in/out cat. Cat is in stock location so the heat shield still protects my floor. On the exit end of the cat, I had the Flowmaster y-collector welded to the cat, in reverse. The y-collector is made to feed two pipes into one. I'm using it to feed one into two. The y-collector is 3" in, dual 2-1/2" out. So then I ran two 2-1/2" pipes over the axle out the back. One goes straight back, the other goes over the end of the driveshaft to the other side. Not enough room to have two pipes go back on one side. ![]() ![]()
Man I hate it when he posts pictures. Just makes me relize how much more stuff I still have left to do to mine
So if I used a flowmaster I could do it the way I stated above?
What if I use and Aerochamber will the inside of that burn up? The Aerochamber is a little cheaper then the Flowmaster and alot of guys on here seem to like them. I have not decided yet. So will the aerochamber burn up? Im trying to eliminate going over the axle. Not only to save money but so I have less back there. Mike where do your pipes exit, right out the back? Thanks for posting the pictures I appreciate it alot. Tom Im gonna need to check out your setup. When you coming by? Is your truck(s) running?
#9 | |
I'm back with 2nd truck!
![]() Eddie- I also have pics here of the exhaust of mine not like Mike's though http://www/geocites.com/cjhicks1/exhaust.html
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Brandon:
I had some trouble getting your site to work. I had to refresh it a few times, then it worked. I like your exhuast, if I was gonna go with duals, I would do something similar to that. Does the X pipe ever interefere with your drive shaft?
No not at all. It is behind the tranny tail and below it so it has no trouble at all.
Eddie, your in luck. My truck is running and driving as of last night.
I still have to go home and tune it correctly, and attach the tranny to the crossmember, but it will get to the tire store for new tires tonight ![]() By next week I should be able to come over.
#13 |
Top Notch!
which one is running? Brandon: Can you tell me how much your entire exhuast system set you back? I dont plan to do it, because Im sure it will cost more, but I still like it and am interested.
#14 |
the white one foolio. Gots to get the daily driver going again before the toy.
#15 | |
#16 |
Actually you do have a couple of low cost options here that might do just about what you described.
One is a little noisy than the other. I'll describe the quieter one as you really don't need all that noise right behind the cab. Dynomax makes a version of the Super Turbo muffler called the HD Super Turbo. Its designed for BBC RV's with single exhaust that will not blow apart or rust out too quickly. These sell for about $60 and come in 2 and 2.5 31 to 35 inches long. They flow very well and are fairly quiet. You will need to take some measurements its tight under there from the cat back. I have also used the Hemi Super Turbo with very good results in single exhaust setup like you descibed. It is designed to work with BBC, its cheaper, but a little throaty. Best for behind the wheel or under the bumper. A 2.5 single exhaust with a high flow muffler will give you very good street performance at a very reasonable cost. On an exhaust system this short you might get some popping at the tail pipe when you back off the throttle. This is unburned gas igniting in the pipe, a small resonator tip with fix this. Just a thought, good luck. Lester |
#17 |
Yep....I have it dumping out right infront of the driver's side tire with no muffler....definately some popping when backing off the throttle quickly....but it's not as bad as i thought it would of been....come friday this will probably be remedied tho.
