09-30-2009, 11:47 AM | #1 |
60-62 Auto Trans Mount & Drive Shaft Wanted
I need a crossmember from a 60-62 Chevy pickup which came with a powerglide. It bolts in to the X frame with 3 bolts on each end. A drive shaft from same vehicle would be great! Thanks
09-30-2009, 09:38 PM | #2 |
Re: 60-62 Auto Trans Mount & Drive Shaft Wanted
RU keeping the powerglide or switching to something different?
10-01-2009, 05:34 AM | #3 |
My truck came with a standard transmission, thus no auto crossmember. If I get the drive shaft from someone else's truck that had a powerglide, I'll probably put in a 350 Turbo of the same length just for convenience. If not, I'll probably go with a 700r4 and have a drive shaft made up. Either way, I'm doing away with the standard trans and going with a late model automatic. So, I mainly need the crossmember! Any suggestions are appreciated.
10-01-2009, 02:45 PM | #4 |
Try here for some good info.
http://persh.org/Pickup/IdeaPage.htm |
10-01-2009, 06:42 PM | #5 |
Thanks D! I checked it out and it is great info! TT
10-01-2009, 09:53 PM | #6 |
Which College Grove are you in?
10-01-2009, 09:57 PM | #7 |
You should also check us out over here...
http://tennesseeclassictruckclub.com\ |
10-02-2009, 03:14 PM | #8 |
South of Nashville between Franklin and Murfreesboro. Where are you located? TT
10-09-2009, 09:21 PM | #9 |
I am over to the east- about 35 mile east of Knoxville. 1/2 an hour from Gatlinburg. WE got several guys from the TNCTC board in your neighborhood.
10-15-2009, 09:22 PM | #10 |
Junior Member
I have a crossmember (chrome) that I was going to use in my 66 that I would let go cheap. Not sure if it fits your year or not, but it is for TH350.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
10-16-2009, 07:42 PM | #11 |
what is cheap?
10-16-2009, 09:46 PM | #12 |
Junior Member
$50 plus the freight. I'm going to Memphis the first weekend in December if that would help on the freight part.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 10-16-2009 at 09:50 PM. |
10-16-2009, 11:45 PM | #13 |
PM returned
