Old 09-30-2009, 04:01 PM   #1
gripnrip
Gripnrip
292 removal
I'm in the process of removing a 292 from a 67 3/4 ton to be rebuilt and replaced, can anyone tell me the best place to mount hooks to the block to remove it from the truck?
Also I would like info on applications for an automatic with overdrive to fit behind the 292. Thanks for any help.
gripnrip is offline   Reply With Quote
Old 09-30-2009, 11:47 PM   #2
MXmaniac
MXmaniac's Avatar
Re: 292 removal
I bolted a length of chain to the front of the head, ran the chain diagonal across the head to the rear and bolted it to the rear as well. I think I used a manifold stud in the rear, and I don't remember which hole on the front passenger side of the head. Then lift from a point on the chain that best balances the motor.
I'll let someone else chime in on the transmission question... but I do know that the 292 has the same bellhousing bolt patern as a SBC, so I'd think anything that'll fit a SBC will work with a 292.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
