09-30-2009, 08:40 PM | #1 |
ASAP mechanical fuel pump inlet
I have fuel to my fuel pump but the engine is not getting fuel. I am wondering if the inlet and outlet of the fuel pump lines were switched.
Can anyone tell me which nipple the fuel inlet line comes in on? looking at it from the top down or from the bottom.... PLEASE!!! trying to work during daylight hours...a |
09-30-2009, 08:45 PM | #2 |
PROJECT 7DEUCE
Re: ASAP mechanical fuel pump inlet
With the pump mounted on the motor the one closest to the block goes to carb the othe goes to the fuel supply line..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-30-2009, 09:07 PM | #3 |
I have a 3 line pump on the truck. Im guessing it is a return line for some reason on the third one. Can I run a 2 line fuel pump instead?
09-30-2009, 10:15 PM | #4 |
1968 C20 Vortec Beast
The return nipple should be a smaller diameter if I remember correctly.
Ugly or not it still kicks a**! |
10-01-2009, 11:28 PM | #5 |
5/16 barb is the inlet for the pump
1/4 barb is the return line to the tank. 5/16 i/f is the outlet to the carb. |
10-02-2009, 12:13 AM | #6 |
its all about the +6 inches
if its an inline or 2 bbl small block it'll be 5/16ths, a v6, 4 bbl small block or any big block will be 3/8ths
