Old 09-30-2009, 09:18 PM   #1
rico7769
Hybrid67
rico7769's Avatar
Heater Core Deletion
I have seen a few threads on removal and deletion instructions for a heater core but I have a question regarding the performance once it is gone. I want to clean up the look under the hood and patch the holes with a delete kit to get ready for paint. My question is "will it affect the temp or any engine performance due to cooling?" I know it functions to dissipate the heat as a "small radiator" but primarily provides the heat for the blower in the cab. I've read I can plug the water pump and intake or reconnect the hoses but I don't want to affect anything mechanically. Anyone tried it and had pos/neg effects?
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 09-30-2009, 11:22 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Heater Core Deletion
Most heater deletions I have seen usually came to be because the core was leaking and the vehicle owner bypassed it by looping the heater hose so the coolant circulated w/o passing through the core. I don't see that the effect of NOT passing coolant through the heater core will adversely affect your cooling. After all, GM sold these trucks new w/o heaters in some markets. They would not have done so if there was any cooling benefit to be gained. You gotta remember that those markets were in warm climates where a heater wasn't necessary.
Member Nr. 2770
Old 10-01-2009, 12:39 AM   #3
mclairmo
No effect on engine. My truck and my Camaro have no heater anymore. However, if they ever overheat I cannot turn on the fan on high and turn on the heater to help cool the engine in a pinch. Nice to keep the heater for those rare emergencies.
mclairmo is offline   Reply With Quote
Old 10-01-2009, 10:12 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
I bypassed the heater core on my truck. Runs at the same temp as before.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-01-2009, 10:28 AM   #5
big_al_71
big_al_71's Avatar
Mine was taken out completely and then I shaved the firewall, zero changes in performance and no need for heater in Florida..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-02-2009, 05:13 AM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
GM designed these trucks with beefy cooling systems. After all, they are trucks. Remember when they were designed, GM knew they would be carrying heavy loads, pulling trailers, etc. Go ahead, take your heater out.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-02-2009, 05:38 PM   #7
rico7769
Hybrid67
rico7769's Avatar
Thanks everyone. Heater's comin out!!! Great to have good people with correct info on our site. Appreciate all the info.
Keep em' Running!
All show.....no go
