Old 09-30-2009, 10:53 PM   #1
Daves72'GMC
Question '72 front disk brake pad ?
My outter disk brake pad on the left front was moving around and making noise,So I bent the tabs down over the caliper ,but the pad moves up and down ,how do I take up the play with this movement.Thank you.
Daves72'GMC is offline   Reply With Quote
Old 10-01-2009, 12:02 AM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: '72 front disk brake pad ?
um that shouldnt be happening, sounds like you have a caliper issue, with possibly the slide bolts. that pad shouldnt move at all. do you have all the hardware in the caliper?
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 10-01-2009, 07:12 PM   #3
Daves72'GMC
Question Re: '72 front disk brake pad ?
What all is suppose to be there? and I'll have to pull it apart and check it. check
Old 10-01-2009, 07:37 PM   #4
BAGNDRAGIT
BAGNDRAGIT's Avatar
this is the hardware kit.
http://www.autozone.com/autozone/cat...&parentId=44-0
how many new parts are on the brakes?? old calipers? old hardware?
Previous:
1969 Volkswagen Bug
Old 10-01-2009, 08:14 PM   #5
Daves72'GMC
Smile Re: '72 front disk brake pad ?
I sure appreciate it. I'll have to take it apart and check to see what is going on . Thank you . Dave
Old 10-01-2009, 08:34 PM   #6
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
If you are saying the pad moves up & down in the caliper, that means the tabs aren't bent tight enough. It is hard to bend/ beat/ squeeze them tight enough while on the caliper. Take them off, bend them a little "too tight" and squeeze them on with a C clamp. That will give them a snug fit. Also make sure that the inner pad ahas the spring tension clip on it, that snaps into the piston.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 10-02-2009, 08:27 AM   #7
Daves72'GMC
I'll give it a try,Thank you . Dave
Old 10-03-2009, 12:06 AM   #8
Daves72'GMC
I've got the 2 long bolts out,Whats the best way to compress the piston into the caliper?Thank you.
Old 10-03-2009, 12:35 AM   #9
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
To get the caliper off, pry with a big screwdriver or small prybar. To compress the piston with it off... a c- clamp or c- clamp Vise Grip.
Old 10-03-2009, 02:27 AM   #10
Daves72'GMC
Thank you.
Old 10-07-2009, 09:58 PM   #11
Daves72'GMC
Just wanted to thank everyone for all of your help, i took off both calipers and bent the tabs to tighten the pads on the calipers to keep the pads from moving and it worked perfect,they don't move at all anymore. Thanks again . Dave
