Old 10-01-2009, 08:16 AM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
OIL PAN GASKET In truck???
like it says can I get a new oil pan gasket in with out a big BS production....PO cranked all gaskets till they squishd out now my truck is a strainer...
327 auto 2wd C10
thanx
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-01-2009, 08:52 AM   #2
cdowns
cdowns's Avatar
Re: OIL PAN GASKET In truck???
motor needs to b lifted a few inches to remone pan for gasket replacement// best to use the pricy rubber one piece gasket//while the pan is off check for damage to the bolt holes due to overtightening
Old 10-01-2009, 09:04 AM   #3
Hottrucks
Hottrucks's Avatar
Crap not what I as hoping to hear......looks like I may try to paste it up for another month then just pull it and do the pan, timing cover an rear main... guess I'll cam it to while it's out then I can repaint and clean up the engine bay...maybe find a new clip to hang on it??
Old 10-01-2009, 11:18 AM   #4
michael bustamante
michael bustamante's Avatar
also while youre at it you might as well convert to 5 lug, smooth the fire wall and while youre there, replace all those old cab and radiator support mounts smooth the cowl. . . . . it never ends once you pull the engine!!!!
1967custom
michael bustamante is offline   Reply With Quote
Old 10-01-2009, 11:25 AM   #5
71tahoe
71tahoe's Avatar
327 auto 2wd C10
thanx
Doesn't sound like too big of a production to me. Loosen the motor mounts from the towers, jack up the front of the motor, loosen the perimeter bolts, pull the pan, clean pan, clean block, check threads, reinstall gasket and pan, bolt the engine down, re-fill and check for leaks.
71tahoe is offline   Reply With Quote
Old 10-01-2009, 12:42 PM   #6
Hottrucks
Hottrucks's Avatar
I figured if the pan as leaking I woud just pull it do it right and if a 500 caddy fell back in well then I guess I would just suffer with that..I have to re route myexhaust while I'm there anyway..... I just need to find where I left it (another motor)???...
I can't smooth the fire wall I'm trying to get my ac working and It would be alot harder when it's laying on the floor? but the cab and rad supports are done already so pulling the front clip should be easy....
like I said guess since I only have a month or 2 till snow I'll goop it with some formagasket and what ever blows out I'll chalk up to oil undercoating......
