Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-01-2009, 12:56 PM   #1
ripdog28
ripdog28's Avatar
Nitrous Systems ?
I am planning on adding a 200-250 shot just for fun. mostly street driven. I know the plate systems are cheaper but have been looking at a fogger. Any advise for the set up i should go with any why?
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 10-01-2009, 01:16 PM   #2
wheatlandbrawler
wheatlandbrawler's Avatar
Re: Nitrous Systems ?
foggers are generally used for a few reasons, a fogger can support more stages at a larger flow. and foggers have a better distribution into each individual runner for better atomization. generally most guys that run foggers are running multiple stages of 500hp "shots" for your scenario i would go with a plate system, theirs alot of good plate systems out now for what your trying to do the NOS big shot plate system is a good and inexpensive plate system, or the NX Gemini wich is what i run, or if you can afford it i recommend going with the Wilson pro flo plate system, the plate has burst plates in it for back fires the solenoids are all rebuild-able and billet and the solenoid brackets they have are awesome for keeping it clean.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 10-01-2009, 02:11 PM   #3
djracer
djracer's Avatar
Wilson makes great nitrous stuff but I would avoid the plate with the burst panels. I have a friend that has had trouble with them and he runs NA most of the time. If you are gonna run a plate you might want to look at the Speedtech diffusor plate. Thats what I had on my truck at Pass Time.
Mine will have a fogger with big jets next time out.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-01-2009, 02:16 PM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
The biggest advantage with foggers over plates is the amount of fine tuning they provide. You can tune each individual cylinder on both nitrous and fuel sides. If you've got a hot cylinder you can pull some no2 jet out. With a plate you pretty much have to tune the whole system off the "worst" cylinder. I run a fogger setup on my camaro (LSx motor) with a 200 shot.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 10-01-2009, 04:50 PM   #5
ripdog28
ripdog28's Avatar
Wilson is to much, i would go with a fogger for that price. I have a Dominator intake and an adaptor for 4150 carb. not sure if setting a plate on the top or bottom will make a diffrence. Thinking the higher it is, the better it will dispurse.
69 c-10 BBC
Old 10-02-2009, 12:51 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
At 200-250 id go with a NOS cheater/Edelbrock plate . That would give you the ability to go smaller if you wanted . The tune ups are easy and proven . The plate is alot easier to install .
A fogger looks cooler and will hit the tires softer than a plate . The manifold also needs to be set up in a mill for the holes to be drilled so it will look semetrical piping wise . Tuning for a fogger is alot more precise .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-05-2009, 04:17 PM   #7
J_PEPIN87
J_PEPIN87's Avatar
I agree with hotrod80 the plate is a lot easier and more simple to install but the fogger looks a lot more cool.
J_PEPIN87 is offline   Reply With Quote
Old 10-08-2009, 04:12 PM   #8
Outlaw72
Hay Team!!
Outlaw72's Avatar
You want your plate to be as close to the cylinders as possible.....so your plate would go UNDER your adapter. I started out on a NOS big shot, it was a great starter kit for what I wanted to do. I still have a plate but I moved on to a cold fusion setup that uses a square jetting method. I've blown up everything in my truck except the engine.....lol And the engine even had hyper pistons in it
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
