10-01-2009, 04:21 PM | #1 |
406 Powered
Ok im considering the drop.....help please
I am thinking of lowering my truck after i get my new motor in. How low can i go with just coil springs and drop shocks? Is it 3 front 4 rear? Please post pics of your trucks lowered with just springs and drop shocks.........thanks fellas
70 GMC 68 c10 2002 silverado 72 4x4 Last edited by BADPURPLE70CHEVY; 10-01-2009 at 06:15 PM. Reason: Add something |
10-01-2009, 09:11 PM | #2 |
406 Powered
Re: Ok im considering the drop.....
Someone please post some pics......
70 GMC 68 c10 2002 silverado 72 4x4 |
10-01-2009, 09:21 PM | #3 |
Project 7dos
5.5/4
2.5 in spindles + 3 in coils/ 4 in coils
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 Last edited by chevjayfsd; 10-01-2009 at 09:21 PM. |
10-01-2009, 09:41 PM | #4 |
here are some old picts of mine 2/4 with just springs
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-01-2009, 10:02 PM | #5 |
Eat My Rust
3" front drop springs. Bump steer is minimal, just take it to a good alignment shop.
10-01-2009, 10:23 PM | #6 |
Man of Mini-Talents
How much can you drop the back before you have to c-notch it?
How do you determine how much you need to drop when you don't know if the current heght is normal or due to sagging springs? Or does it really matter since the new springs will give it the right height? |
10-01-2009, 11:01 PM | #7 |
I now have a 4/6 drop on my truck with no c notch so I can say you can go with 6 inches maximum in the rear...
10-01-2009, 11:21 PM | #8 | |
67-72 parts collector,…
Check out ECE's stance photos for a look at different drops. Look here: http://www.earlyclassic.com/tech.asp...nce%20Photos-2
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-01-2009 at 11:22 PM. |
10-02-2009, 08:38 AM | #9 |
Tot Roddin'
It's about time you crossed over...
Trust me, once it's down you will wonder why you didn't do it earlier. As lolife99 has posted above, as well as several others, I would highly recommend ECE's products. I know you don't want to go to low, but with my 4.5/6 drop on my '69, everything went together and I didn't have to worry about missing parts or unanswered questions.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
