Old 01-16-2003, 12:21 AM   #1
cacauba
STL-KKN
cacauba's Avatar
running bad
okay first off my motor is the original 350 and has 160k. needless to say it needs rings and has no power. but recently i have started driving it again daily, and have noticed a very strong ratteling sound from the motor but only under load. i check for exhaust leaks but found none, then i replaced the splugs and wires. the ratteling sounds like a missfire or and exhaust leak but very rappid. i know this is nothing to go on but i cant figure it out, and if it's something simple then i will just feel stupid not fixing it. my next thoughts are that it is the rocker arms, but i'm not sure how to check them for looseness. let me prethank anyone for there input
1969 C10 350/POWERGLIDE
1991 1500 EXTCAB 350
Formally: collegeK5er
cacauba is offline   Reply With Quote
Old 01-16-2003, 12:35 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Spark knock?
Try a higher grade of fuel.
(like 10 MPG on 87 octain isn't expensive enough)
Old 01-16-2003, 12:45 AM   #3
cacauba
STL-KKN
cacauba's Avatar
will a fuel addative help?
Old 01-16-2003, 12:50 AM   #4
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
10 miles to the gallon?!?!?! I wish I had 10 to the gallon. My old beater won't get but like 5-6 per gallon
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
