![]() Join Date: Sep 2007
air valve line installation
Im at the piont now where I need to set up my valves. (8 of them) so how exactly do these things work? I mean how do I set up the air lines for them? I get how the fills work but Im seeing on other peoples threads how they have 2 or even for connected with T pipe. I guess I dont really understand how these valves work together. can some one help me out or send my a link to plumb these?
thanks Heres my set up 1 compressor 1 tank with 8 ports 8 valves 5, 3 way switches for fbss and drop 2 two needle guages which reminds me where do I put the "t"s for the guages to read properly on each bag? before or after the fill valve? 3/8 line all the way around
1967custom Last edited by michael bustamante; 10-01-2009 at 04:53 PM. Reason: cuz I dont know how to type good |
AIRBAGPARTS.COM
Re: air valve line installation
Your gauge line goes between your fill and dump valves for each bag.
AIRBAGPARTS.COM
Also, I do have a diagram somewhere. I will try to find it and post it up for you.
thank you man I d REALLY appreciate it. Also can you pm me a price for 2 3/8 valves shipped to NM. if you cant Ill go on your web site again
1967custom |
got your quote man thank you and Ill let you know. Ill be ordering these as soon as I get back from vacation, any luck on that diagram yet?
1967custom |
Epoxy Primer Friendly
[IMG]http://www.*****************/files/how_to/wire-diagrams/8valve.gif[/IMG]
[IMG]http://www.*****************/files/how_to/wire-diagrams/valveassembly.gif[/IMG] Last edited by camaro__thunder; 10-02-2009 at 03:22 PM. |
thats what I needed man thank you. one more thing, I noticed these valves have in and out. now for the dumps, which side does the air come out of? I have seem them mounted where the inlet is not the side that the 4 way is mounted to
1967custom |
AIRBAGPARTS.COM
All valves should have an arrow or some sort of marking that show which way the air flows.
they do but ive seen where the outlet side was mounted to the four way on the dump valves. is that right? I would think the it needs to be mounted inlet side to the 4 way for both lift and dump valves
1967custom |
ha!!! I finally figured it out!!!. thanks for your haelp and for the diagram. I appreciate it.
jason: Ill be contacting suicidedoors for them valves when I get back from cincinnati. thanks again
1967custom |
