Old 10-01-2009, 07:15 PM   #1
capev86
HO52 gear swap preparations
i am hoping to change out the 4.57 gear for the 4.10 on saturday. i have a lot of the stuff ready to go but want you all to check my grocery list. is there a gasket for the third member to diff housing surface or do i just use rtv? i am planning to do both on the diff cover. they make a rebuild kit but the third member i am installing was reportedly serviced a year ago and i haven't had cause to susepect any bad bearings or such over the last several months of driving it. someone mentioned in an old thread about changing the cap when doing the swap. there is a cup and cone according to the list of part numbers i have.
what i have:
4.10 third member
napa diff cover gasket
permatex hi-temp silicone rtv
axle seals
royal purple 75w-90 gear oil
capev86 is offline   Reply With Quote
Old 10-01-2009, 09:54 PM   #2
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Re: HO52 gear swap preparations
I really like this rearend setup. I blew up the 456 gears in mine and a friend had totalled his 70 that had 373s it is so easy to do the swap. Dropping out the third member and being able to build it as far as you can on a bench is nice. There is a gasket for it and I actually used it on both sides (ie gear and pan side). There are also gaskets to seal the axles to the hub but I just dope it with silicone. I just wish a posi was able to be found. I even checked with Eaton directly and they don't have them.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 10-01-2009, 10:52 PM   #3
factorystock
factorystock's Avatar
Once axle shafts are removed, it will drop out. Its heavy, so have a floor jack under it. There are 2 different gaskets needed for job. One is thin, for front carrier housing, the other is thick, for cover.Also you'll need a pump to get gear oil back in. Metal axle shaft gaskets can be reused with RTV sealant.
factorystock is offline   Reply With Quote
Old 10-03-2009, 03:59 PM   #4
capev86
hey Stueber68.......how did you get a 3.73? i feel lucky to have found a good 4.10 for the price i paid. rain and other things have prevented me from tackling the project this weekend.
Old 10-03-2009, 06:37 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was wondering the same thing when I saw that... never heard of a 3.73 in an eaton HO52 or HO72
Old 10-04-2009, 10:03 AM   #6
Rod
So would I like to hear more about the 373 eaton H052 gear set.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
