10-01-2009, 09:20 PM | #1 |
"THE GREEN GOBLIN"
Can I get under dash pictures of 72chevy kickdown hookup
Hello me again I am looking for some pictures of the stock pedal kickdown setup found on 72's pictures of the wireing where does the wire go hooked up to in the fues block? where does the pink wire go on top or bottom? Orange wire on top or bottom of switch? and of Stock hole location on firewall where the wire comes through from the engine bay? Thanks again for all the help guys.....
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
10-01-2009, 10:25 PM | #2 |
Re: Can I get under dash pictures of 72chevy kickdown hookup
Hi there, here is some pictures of what I think you're looking for.
on the fuse box its the pink wire at the top between tail-GL. |
10-01-2009, 10:28 PM | #3 |
Then the orange wire goes out the same hole as the oil line, then loops up to the gutter with some slack the a plug connector.
10-01-2009, 10:30 PM | #4 |
Then it goes down with the tail light harness
10-02-2009, 02:16 AM | #5 |
"THE GREEN GOBLIN"
Great pictures thanks guys for the help
Petey-pablo
