Old 10-02-2009, 09:50 AM   #1
damnyankee36
damnyankee36's Avatar
Best Fitting Headers For a 66
I know this has been discussed before, but my searches haven't given me a definitive answer about header fit on the 60-66 trucks. It seems all the discussions were based on the 67-up.
Who has a SBC with shorty headers installed in their 66 that fit with no mods? I have an auto transmission. Can anybody tell me what brand they use?
Another issue I found was that, apparently, the 60-66 trucks have a narrower frame cross section than the 67-up. That might be something in my favor.
I like the ceramic coated headers and looked at the Sanderson's, but I was hoping for something a little cheaper.
Thanks again!!
damnyankee36 is offline   Reply With Quote
Old 10-02-2009, 10:35 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Best Fitting Headers For a 66
These are some headers I bought at Kragens. I can't remember what brand name they are but the Summit headers work just fine also. The 3rd picture of the truck are these headers http://www.summitracing.com/parts/SUM-G9006-9/# from summit. They are $216. They are the last picture.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-02-2009, 02:03 PM   #3
Jakes-66-K10
Jakes-66-K10's Avatar
Curious about this myself, I've seen alot of headers hang too low below the frame, and "best fit" should be not only between the frame rails but positioned for the best ground clearance too. Anyone used anything they would say is the best fit for our year of trucks?
Jakes-66-K10 is offline   Reply With Quote
Old 10-02-2009, 03:43 PM   #4
damnyankee36
I'm starting get somewhere on this. I've narrowed it down to the Summit G9060-1 and the Speedway Motors 9300100H and 9300101H.
The 100H, is described as: $160:
"These S/B Chevy tight fit headers fit even difficult applications where space is limited. For round port S/B Chevy. 1-1/2" primary with 2-1/2" collector. Complete with reducers, gaskets, and bolts. Will not fit angled plug heads".
The Speedway 101H, $200:
"These small-block Chevy tight-fit headers are the most universal steel tube headers available. They even fit difficult applications where space is limited. They are a favorite for street rods, as well as many 1950's and 1960's cars and vintage trucks".
Both are ceramic coated and have 1-1/2" and 1-5/8" primaries, respectively.
Since this design is closer to the style of the ram horn manifolds, I don't think I will have to worry about fitment problems like the "swept" back ones.
It looks like the only difference between the two are the primary pipe size.
Old 10-02-2009, 04:15 PM   #5
Joemomma1
Joemomma1's Avatar
Im running a set from a 60s-70's camaro/chevelle. Does not hang past the frame rails. Fits nice.
Joemomma1 is offline   Reply With Quote
Old 10-02-2009, 04:19 PM   #6
Sicboy
Sicboy's Avatar
I just bought a set of Speedway's Tru-Ram cast iron manifolds for my 327 rebuild. Right now they're at the ceramic coaters being coated in shiny ceramichrome.
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 10-02-2009, 08:11 PM   #7
damnyankee36
I found these for sale. He says they are D port headers. I thought a D port header would be shape like a D.
What's everybody think?
Old 10-02-2009, 08:53 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
I used Summit shorty's for a 88-98 pickup small block. Dont fit your no mods, but very close. I welded the O2 sensor shut and had a slight clearance issue with the drivers frame rail...my engine is in the forward position, if you were in the rear position it would have cleared I believe.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-02-2009, 09:06 PM   #9
chris6499
chris6499's Avatar
i have block huggers on mine now they are ok but i want to replace them with some shorty headers should beable to tuck the exhaust up higher with the block huggers the exhaust hangs to low
chris6499 is offline   Reply With Quote
Old 10-02-2009, 09:32 PM   #10
protrash64
protrash64's Avatar
Yes you will....with the shorty's I used, I was able to run the exhaust past the trans and thru the x-member. It's completely above the bottom of the frame.
Low points become front control arms, trans pan, and the oval in the x-member behind the trans.
Old 10-02-2009, 11:49 PM   #11
Bennydog
Bennydog's Avatar
Ive got hooker comp headers on my 65 sbc350 fit good no issues
Grandpas and Dads and now my 1965 C-10
1975 SWB C-10
Bennydog is offline   Reply With Quote
Old 10-03-2009, 12:12 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
ive got my motor in the rear position, and im running hooker supercomps. they were slightly massaged but it didn't HAVE to be done
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-03-2009, 12:20 AM   #13
Captainfab
60-66 Nut
Take a look at Hedman 69230's they don't hang down much if any below the bottom of the frame. They are also available in ceramic coated.
Old 10-03-2009, 12:21 AM   #14
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
These are what I'm running http://www.summitracing.com/parts/HOK-2466HKR/ check out my build thread you can see some good pics witht he headers on, and if not heres my photobucket http://s581.photobucket.com/albums/s...ent=truck8.jpg
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-03-2009, 01:42 AM   #15
toms84ss
I have the same headers as ruffrida2005 in my 65 with an 87 Burb cross member. No mods, bolt in, don't hang too low. Haven't finished the exhaust yet. Just have them bolted to the engine.
toms84ss is offline   Reply With Quote
Old 10-03-2009, 10:54 AM   #16
shrunken66stroker
shrunken66stroker's Avatar
There have been people mentioning Headman shorties will work. The part number they gave was 69648. I'm thinking about giving these a try.
http://www.summitracing.com/search/?keyword=69648&dds=1
shrunken66stroker is offline   Reply With Quote
Old 10-03-2009, 11:29 AM   #17
damnyankee36
Well, I wound up ordering the Speedway Motors 9300100H. The 101H had the 1-5/8" primaries. The 100H's 1-1/2" is all I need.
http://www.speedwaymotors.com/Speedw...ders,3815.html
Figures they would go back-order!
We'll see how they fit.
Old 10-15-2009, 10:41 PM   #18
damnyankee36
Got the Speedway headers in today.
First thing I noticed was the flanges were only about 1/8" thick. And, when they say they are block huggers, they aren't kidding. The collector looks like it was touching the block the same time the flanges were seated on the exhaust ports. I was afraid once they were bolted down, there might be some stress if they were bending the tubes.
But, I didn't have to worry about finding out if they were going to be stressed. I didn't get that far.
The #3 tube was about 1/16" away from the spark plug!
Since they are ceramic, I figured dimpling the tube wasn't the answer, so I packed them up to send back.
How hard could it have been to move the tube just a little in the design? I guess I got what I paid for.
Old 10-16-2009, 12:22 AM   #19
ruffrida2005
Look at the headers I'm running, I dont have any problem with them. The collector is a little close to the oil filter, but no problem with them at all with the spark plugs.
Paul
Old 10-16-2009, 12:25 AM   #20
damnyankee36
I looked at yours earlier, but couldn't find them with a ceramic coating.
Thanks for helping!
Old 10-16-2009, 12:29 AM   #21
ruffrida2005
Summit does sell them as ceramic coated also. Just type in HOK 2466 and they will come up.
Paul
Old 10-16-2009, 12:34 AM   #22
damnyankee36
You're right, I did find them in ceramic. I'm loosing track of where I've been. I think the price is what made me forget about them.
I think I'm just going to have to pay up for a good quality header!
Old 10-16-2009, 07:39 AM   #23
lakeroadster
Wise statement.
Price is important, but quality is more important. I have found that when it comes to headers that if you can find one made for your application that the big boys build a better product. I know from first hand experience that Doug Thorley, Hooker and Sanderson build a very good product. Heavy flanges, tubes designed so you can actualy get the spark plugs out without being Hoodini, and clearances so you don't have to take the ball peen hammer to your brand new headers.
And go with the ceramic coating -or- better yet buy them raw, make sure they fit, and then send them out for coating. It keeps underhood temperatures down and makes the header last much longer, especially in areas where salt / mag chloride is used on the roads during the winter.
lakeroadster is offline   Reply With Quote
Old 10-16-2009, 10:46 PM   #24
babyblu63
anyone know of headers for stock motors? i have the 292 straight six.
babyblu63 is offline   Reply With Quote
Old 10-17-2009, 12:31 AM   #25
Captainfab
60-66 Nut
Have you checked with these guys?
http://cliffordperformance.net/
