10-02-2009, 02:04 PM | #1 |
Timing Question
I have a 350 crate motor that is all stock running a edelbrock1406 carb, and a HEI Skip White distributor. When I first set the timing I had it set at 12 degrees initial and while it idled OK, it would stumble when trying to accelerate. I then advanced the timing till it would run decent and now it is at 24 degrees initial. Also, the total advance timing is 40 degrees at 2,000 RPM’s. Something seems way off. When I first set the motor up I did verify that TDC was 0 degrees on the timing tab. Any ideas? David
10-02-2009, 02:20 PM | #2 |
Re: Timing Question
New or old balancer? Verify it has not slipped. Are these numbers with the vacuum advance can plugged or not?
10-02-2009, 02:21 PM | #3 | |
Re: Timing Question
So I'm not saying yours IS correct, but it MAY be correct. |
10-02-2009, 02:23 PM | #4 |
Re: Timing Question
10-02-2009, 02:26 PM | #5 | |
Re: Timing Question
10-02-2009, 03:47 PM | #6 |
Re: Timing Question
I set mine up for 14 base and 37 with mechanical and a total of 55 at 3000 rpm. It seems to work the best at that setting. I have a MSD ready to run distributor that I had to change the springs and bushing to get it to 37. Vacuum advance is not adjustable. I am also running an Edelbrock carb and EPS manifold with a 1" spacer.
10-02-2009, 05:51 PM | #7 | ||
Re: Timing Question
37 degrees of centrifugal timing seems a bit out-there? but then so does running w/o vacuum advance on a street vehicle.
(All of that initial advance would be required to make it run w/o having the vacuum advance connected).....but it doen't make it right. The only reason to run w/o vacuum advance is in a totally wide open throttle situation like drag racing. Quote:
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-02-2009, 06:01 PM | #8 |
Re: Timing Question
Actually that is base and mechanical for a total of 37. It would be 23 mechanical. I am also running my vacuum advance off manifold vacuum. The truck runs great. I never have a problem starting. It normally starts with the first touch of the key. Power is good but found more by changing the rods in the carb but it was using to much gas. I am now trying a quadajet to try to imporve my mileage but I think I have a warped stock aluminum egr manifold because it is not running right. It falls flat on its face when I lay on the throttle with a Jet Stage 2 and doesn't do much better with a stock Q-jet. I am going to try the Edelbrock on the manifold to confirm it is not the carb.
10-02-2009, 06:56 PM | #9 | |
Re: Timing Question
I'm not running it with no vacuum advance. Only to time it. |
10-02-2009, 10:27 PM | #10 |
Re: Timing Question
All of these timing numbers are off the scale.
You shouldn't be running more than 37 degrees TOTAL advance at 3000rpm. My base advance is 10 degrees without vacum. Even with Super Unleaded I get a ping if I try to advance it any further. When you set your initial timing with the vacum advance disconnected and plugged off are you sure your engine is idling around 800-1000 rpm? If not then you're getting some mechanical advance unless your springs are extremely stiff. I'd run it down to a machine/performance shop and let someone set the timing for you with an inductive timing light. Or cough up about 300.00 and get your own. Last edited by highperf4x4; 10-02-2009 at 10:30 PM. |
10-03-2009, 02:00 AM | #11 |
Re: Timing Question
I like to shoot for about a 34 degree TOTAL @ 3000 rpms (vac can unhooked & plugged) on a 9.5- 10 to 1 pump fuel engine. Add 10 to 12 degrees vac advance, & you are in the ball park. some like a little more, some a little less, depending on the combo(comp ratio,cam ,ect). a lot of those old small blocks will pull tween 48-52 degrees (no load, with the vac can hooked up), with no problems. if it spark rattles @ part throttle. it has too much vac advance....spark rattle @ WOT , too much initial/mechanical advance. best of luck,crazyAl
http://community.webshots.com/user/hotrodhorn |
10-03-2009, 03:18 AM | #12 |
70 Chevrolet=Obsession
Re: Timing Question
Do you have a vacuum gauge? Ported vacuum should be about 20" at 3500RPM. If it's much lower or the gauge needle wiggles at idle, then you have a problem.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
10-03-2009, 11:12 AM | #13 | ||
Re: Timing Question
Sorry, I didn't mean to confuse, I was refering to 69GMCLonghorn about the lack of vacuum advance.
You are correct in timing w/ the vacuum advance disconnected. Quote:
10-03-2009, 12:58 PM | #14 |
Spanked once
Re: Timing Question
Hawker, I have the same set up in my '55 and had the same issue.
Final result 11+ initial and got the metering kit for the 1406 and used the smallest rods I could use without changing the jets , at least that was my sweet spot. Also changed the primary pump setting. It just wasn't getting enough fuel.
The ole 350 budget build. |
10-03-2009, 02:26 PM | #15 | |
Re: Timing Question
10-03-2009, 03:14 PM | #16 |
Spanked once
Re: Timing Question
Changing the rods and the pump setting are simple. You can get the manual off of edelbrocks site. The primary pump only has two settings and is on the right front.
This should help... http://www.edelbrock.com/automotive_...ers_manual.pdf Have fun
10-03-2009, 03:35 PM | #17 |
Classic Chevy Recycler
Re: Timing Question
What kind of heads are you using? If you have vortec heads you have to use the right spark plug or the timing will be like that.
2004 Chevrolet Trailblazer EXT 1970 Chevrolet C50 1979 Chevrolet C30 Need another 67 or 68 soon... |
10-04-2009, 06:44 PM | #18 |
Re: Timing Question
10-08-2009, 10:15 AM | #19 | |
Re: Timing Question
10-08-2009, 01:23 PM | #20 |
Re: Timing Question
What calibration point are you at on the calibration chart?
10-08-2009, 01:24 PM | #21 |
Spanked once
Re: Timing Question
I don't remember which hole but whatever dumps the most fuel. You may be good where your at ,mine is a 290 hp with headers. Glad you got it.
10-18-2009, 09:19 PM | #22 |
newly minted old timer
Re: Timing Question
? why is the vortec differeant?
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
10-18-2009, 10:50 PM | #23 |
Re: Timing Question
the spark plug is different. the threaded part is longer. If you use the regular plugs you have to run the timing up to get it to run decent.
10-18-2009, 10:55 PM | #24 |
Re: Timing Question
huh, well, this may be my prob. i was planning on getting some new plugs tomorrow. i called jegs to ask what plug was recomended for the head i bought. i am having timing issues. had to advance the hell out of the timing like you said.. perhaps the plugs will help
