Old 10-02-2009, 03:50 PM   #1
VanceH
Loving the Jimmster
VanceH's Avatar
New Heater Valve NO HEAT???
ok i have a 72 jimmy with A/C, i was always getting heat, so i replaced the heater shut off valve, and now i get nothing but cold air??? I thought i had it on backwards so i turned it around but still the same???
Any ideas
thanks
Vance
VanceH is offline   Reply With Quote
Old 10-02-2009, 04:00 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: New Heater Valve NO HEAT???
2 things to check. 1 is the valve working? If not do you have good vacuum going to it? 2 Is your system full of water? WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-02-2009, 04:19 PM   #3
john
member #16
john's Avatar
Do you have the right valve? some open with vacuum others close with vaccuum. Just a thought.
john is offline   Reply With Quote
Old 10-02-2009, 04:20 PM   #4
VanceH
Loving the Jimmster
VanceH's Avatar
Not sure how to check if it is working?? Where is the main vacuum block for this? and plenty of water. The old one was not shuting off so i was getting hot air all the time, there is a vent under the cowl that is ran by a vacuum as well??
thanks
Old 10-02-2009, 04:21 PM   #5
VanceH
Loving the Jimmster
VanceH's Avatar
It was the one that LMC had?? Ihope it was the right one.
Old 10-02-2009, 04:49 PM   #6
john
member #16
john's Avatar
Might check the source. Looks like it should heat with no vacuum to the valve. Good luck.
Old 10-02-2009, 05:18 PM   #7
VanceH
Loving the Jimmster
VanceH's Avatar
where is the source? and were is the control head vacuum switch, i am assumming that it is under the dash somewere???
Old 10-02-2009, 05:46 PM   #8
john
member #16
john's Avatar
Goes from the vacuum reservoir to the backside of the a/c control on the dash. Some models have three lines on the control instead of two with a tee as shown.
Old 10-02-2009, 06:23 PM   #9
VanceH
Loving the Jimmster
VanceH's Avatar
ok found the control head switch, the lever that ran it was broke, now fixed, also i found the vacuum res. it had no vacuum lines at all, i found the one from the switch, but i still dont know where the source is?? What does the vacuum source look like, is it off the carb??
Sorry for the trouble
thanks
Vance
Old 10-02-2009, 07:01 PM   #10
john
member #16
john's Avatar
Vance, the source is anyplace you can find full vacuum. Ususally on the intake manifold fitting behind the carb, or off of the carb itself.
Old 10-02-2009, 07:03 PM   #11
VanceH
Loving the Jimmster
VanceH's Avatar
LOL ya figured that one out, been a long day, i have it all hooked up and still not enough vacuum to open the valve, i can suck it open so i know its working, i guess ill head out and tinker some more. Thanks for all the help
vance
Old 10-02-2009, 07:18 PM   #12
john
member #16
john's Avatar
Sometimes the lines just get old and split or crack or fall off. sound like you're on the right track.
Old 10-02-2009, 07:22 PM   #13
VanceH
Loving the Jimmster
VanceH's Avatar
Ok what does the vacuum resorvior actually do? can i bypass this totally, if i hook up each of the vacuum valves to the main source they work fine, but it seems like when i hook up the res i loose suction??
thanks
Vance
Old 10-02-2009, 07:41 PM   #14
john
member #16
john's Avatar
Without the reservoir your valve will shut off everytime your vacuum drops from acceleration etc. Best to keep it or replace it at some point.
Old 10-02-2009, 07:56 PM   #15
VanceH
Loving the Jimmster
VanceH's Avatar
it seems broke is there a way to test it??
