Old 10-02-2009, 08:46 PM   #1
fbaker455
fbaker455's Avatar
gas pedal assembly?
i have a 69 with no gas pedal assembly, i know a guy that has a 72 complete gas pedal assembly, will this parts interchange? i was told the 69-70 had linkage, and the 71-72 had cable.
rides
1982 cutlass 455/350 8.5 3:73 posi (442 clone)
1985 442 350/2004r 8.5 3:73 dailey driver
1969 c10 in progress for work truck
fbaker455 is offline   Reply With Quote
Old 10-02-2009, 09:35 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: gas pedal assembly?
I think you can make it work but the mounting holes in the firewall are different and you have to make a square hole in the firewall for the cable retainer.
LockDoc
Leon
Old 10-03-2009, 09:19 PM   #3
JimKshortstep4x4
The firewalls are actually different between the 69 and 71-72 (with the cable setup).
To convert to a cable style like the 71-72 the firewall will have to be "massaged" or replace the section.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-04-2009, 06:40 PM   #4
cobrajet21
cobrajet21's Avatar
Details about this in the faq section.
http://67-72chevytrucks.com/vboard/s...00#post1383300
cobrajet21 is offline   Reply With Quote
