Old 10-02-2009, 09:37 PM   #1
el cocho
power steering is weak
I just installed a new saginaw ps pump with reservoir. it now takes a lot of effort to turn the tires at a stop or low speeds. before it was a one finger steerer. i have 37x13.5 tires. after install i lifted the front end and cycled the wheel from side to side to try to get rid of air.
do you guys think i got a bum pump, the previous pump was modified, or something else.
what kind of tires do you run with the saginaw and have you made any changes to the pump. there are many varieties of these saginaw pumps with the reservoir attached. it is my understanding that they should all put out about the same pressure.
your help is appreciated.
el cocho is offline   Reply With Quote
Old 10-02-2009, 09:40 PM   #2
71swb4x4
71swb4x4's Avatar
Re: power steering is weak
Why did you replace the pump? Was it hard to steer before?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-02-2009, 10:06 PM   #3
el cocho
it steered with one finger before. it was leaking and decided to just replace while i was in there.
Old 10-03-2009, 10:30 AM   #4
sierra4x4
sierra4x4's Avatar
I have had that happen to me twice. Both times were with Autoline pumps. And In both cases I ended up getting used punp in the end. So I would say you got a bad pump.
sierra4x4 is offline   Reply With Quote
Old 10-03-2009, 12:27 PM   #5
justcuz
justcuz's Avatar
Unfortunately you would have been better off just getting a seal kit and rebuilding it your self. There are ways to modify the pump to make it steer easier. There is a thread on Pirate 4x4 about it.
justcuz is offline   Reply With Quote
