Old 10-02-2009, 09:42 PM   #1
jackyl9999
jackyl9999's Avatar
New ignition switch locked up. Help!!!
I put a new ignition in my project , worked great when I put it in. Even turned it hoping the engine would magically turn over But went to turn it yesterday and now its locked up?! Anyone ever have this happen? If so how do you fix it??
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 10-02-2009, 10:30 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: New ignition switch locked up. Help!!!
Are you talking about a complete switch or just the ignition cylinder and key?
LockDoc
Leon
Old 10-02-2009, 10:32 PM   #3
jackyl9999
jackyl9999's Avatar
I replaced the complete switch.
1990 K1500 Daily
Old 10-02-2009, 11:21 PM   #4
LockDoc
LockDoc's Avatar
Try wiggling the key as you put it in and make sure it is going in all the way. The tumblers could be hanging up inside the lock cylinder. Does the key go in easily? Will it turn to the accessory position? Whatever you do don't try to force it or you will bend the tumblers inside the lock cylinder.
LockDoc
Leon
Old 10-02-2009, 11:37 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
Come on Leon, how would you know anything about locks? I agree, sometimes new lock tumblers can be tricky. Leon covered it pretty well I think. The wiggle trick works often. I've also had a key that was cut too deep (I think, correct me if I'm wrong here Leon), and actually had to pull it out of the switch a tad to get the tumblers to line up correctly.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-03-2009, 08:38 AM   #6
LockDoc
LockDoc's Avatar
.. I'm just grabbing at straws here... Actually, if I was there I could probably figure it out in a couple of minutes but it is hard to diagnose something like this online.
Yes, pulling the key out a tad will work if the cuts are a little deep or the first cut is too far from the shoulder.
LockDoc
Leon
Old 10-03-2009, 10:42 AM   #7
jackyl9999
jackyl9999's Avatar
I'll mess with it and see if I can get something to work today. Thanks for the ideas.
1990 K1500 Daily
Old 10-03-2009, 10:46 AM   #8
70cst
70cst's Avatar
You all have come up with "key" solutions.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 10-03-2009, 06:41 PM   #9
LockDoc
LockDoc's Avatar
.. OK, Korny joke of the day...
LockDoc
Leon
Old 10-03-2009, 08:00 PM   #10
jackyl9999
jackyl9999's Avatar
Got it working. Gave a little tap, well several taps and it's working now. Thanks everyone!
1990 K1500 Daily
Old 10-03-2009, 11:58 PM   #11
LockDoc
LockDoc's Avatar
You have a tumbler or the locking bar hanging up in the cylinder then. It should loosen up with use. If it continues to do it you can try spraying a small amount of spray lube with Teflon in it. Just don't get carried away..
LockDoc
Leon
Old 10-04-2009, 12:29 AM   #12
jackyl9999
jackyl9999's Avatar
Alright I'll put some on it. Thanks
1990 K1500 Daily
