Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-03-2009, 09:19 AM   #1
71-C10
71-C10's Avatar
95 Blazer with cracked dash
I have a 95 Blazer that has cracks in the dash. They run from the defroster vents at the corners as well as from the dash speakers. Whats the best way to repair these cracks? Obviously I can't replace the dash like the pads on my '68 and '71. Lowes sells light gray silicone caulk. If all else fails I might see what I can do with that. Also, how do you change the instrument bulbs? I can't see my temp or oil pressure guages at night.
Eddie
71-C10 is offline   Reply With Quote
Old 10-04-2009, 12:43 PM   #2
Myself
Re: 95 Blazer with cracked dash
They sell an auto vinyl repair kit at Autozone, or you can get it from Eastwood. If you follow the instructions exactly, it will do an acceptable job. The whole plastic trim piece around your gauges pops off. Then you can access the cluster. You have to pull it out and replace bulbs from the back side.
Myself is offline   Reply With Quote
Old 10-08-2009, 10:20 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
how about one of those carpet pad dash cover things molded and shaped to your dash?
68C15 is offline   Reply With Quote
Old 01-13-2010, 01:01 PM   #4
a55togo
a55togo's Avatar
the good thing about the s10's is you can unbolt the whole dash and swap it out for a good one, not epoxy's or carpet dash covers just a full days work.
Ed
a55togo is offline   Reply With Quote
