Floor Shift Steering Column Question ??
Just wondering if someone could tell me how to tighten or reduce the space between the lower bearing and the large washer where the spring is....This is a manual floor shift out of my 70...
The AIM manual says that the space should be around 1/2"...mine is around 1"......and my "before pics" show it at around 1/2" as well......I'm just not sure how to get it there ??......It seems I either need to push the whole Column down and compress it (not sure if the slot on the top of the column is long enough to do that).....Or maybe a spacer behind the steering wheel nut?. I'm lost....any help would be appreciated!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Re: Floor Shift Steering Column Question ??
Loosen the bolts pictured at the end of column tube with 7/16 wrench then you can adjust bearing by rotating hosing. notice how holes are slotted diagonally.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
#3 | |
Thanks for that tip....I gave it shot just now and it only moved it out maybe 1/8" tops....As you can see in the pic there is was only about 1/4" or 3/8" of slot left in the "tighten" direction....I went all the way and the 1/8" or less was the result!.....Still seems quite loose? Your the resident steering column pro....I know you got something else for me to try? Thanks, Dan Here is my before pic: ![]()
TILT COLUMN GURU
Thanks, Dan ] Yes check if cancell cam is the correct one and not damaged. also check upper bearing.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY Last edited by KevsClassics; 10-04-2009 at 01:48 AM. |
I actually re-used the cancel cam that was on there before with the original steering wheel, it looked new and in good shape.....The upper bearing looked fine as well and all in tact...I just cleaned it & re-lubed it.....
I was thinking though that I did upgrade to a quick ratio steering box out of a later model (Wes from Classic Hearbeat said it was direct replacement)....I was thinking maybe by chance that the output shaft is a tad shorter on the later models?.....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 10-04-2009 at 02:07 AM. |
Any other insight on this would be appreciated.....Afterall, its my steering...kind of important...LOL
Just for future reference, in case someone ever has this problem...I did get it figured out...
I simply noticed that the clamp on the intermediate steering shaft was lower on the main shaft than originally...there is a groove in the main shaft for the clamp bolt to reside in.....and that groove is much bigger than the bolt...so you indeed have about 1/2" of "play".... So, I just loosend the clamp bolt, removed the main steering wheel nut and then tapped the shaft down a bit......Then just tightened the clamp on the intermediate steering shaft.....then tigtened the steering wheel nut...thus drawing in and tightening everything up..... Then one final adjustment on the lower bearing to get +or- 1/2" dimension....and I was good to go! RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 10-14-2009 at 01:09 AM. |
