63 airbag location pictures
Im looking for pictures of a 63 with trailing arms with air bags,
I have looked through posts but cannot seem to find pics/only pics of whole truck. |
#2 | |
Re: 63 airbag location pictures
General truck forums --> FAQ ---> Freq ask truck tech --> Krue's FAQ index thread --> Brake & Suspension related FAQ's --> http://67-72chevytrucks.com/vboard/s...d.php?t=129463
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-04-2009 at 08:47 AM. |
#3 | |
low n' slo
![]() Join Date: Mar 2009
not sure about the 63 but on the 67-72 you dont need an upper bag mount. it just bolts up to the frame.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
One of several ways to make them . . .....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-04-2009 at 04:22 PM. |
low n' slo
wouldnt that keep you about 1.5"(or whatever size the cup is) higher than without the cup?
Correct. These were made just tall enough to clear the airline fitting.
low n' slo
ah, so that cup was made so the airline goes through the cup instead of inside the framerail?
Yes. It's bolts in through the original coil retaining-bolt hole in the frame & doesn't require drilling any other holes.
low n' slo
oh ok any pics of the truck?
Not w/those installed. Here's a pic w/o them on bags @ 30psi.....
Looking at the cup you made, could you have put the bag up against the chassis rail and the air pipe fitting inside the chassis rail and then et 1.5" lower ?
#13 | |
![]() Quote:
#14 |
low n' slo
yes, thats what im doing on mine. you can bolt the bag straight to the frame.
#15 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=201898
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-05-2009 at 10:00 AM. |
