Old 10-04-2009, 12:27 PM   #1
tecky11
Refusal to stay running
hi ive got a 55 truck that still thinks it a farm truck. during the day it runs great, but at night it wont stay running, this was previously freqired from 6 volts to 12. the left side of the dash closed by the door gets hotter han a piston. what is wrong with my truck?????
tecky11 is offline   Reply With Quote
Old 10-04-2009, 02:59 PM   #2
OrrieG
OrrieG's Avatar
Re: Refusal to stay running
Is that were the light switch is located? I'd look for a shorting wire or maybe a bad switch that is grounding to the dash metal? Will it start and run with the light off and then dies when turned on??? MIght also be a short in the wires to the lights, dimmer or parking lights.
OrrieG is offline   Reply With Quote
Old 10-04-2009, 05:13 PM   #3
tecky11
Yes that is where the switch is! Even during day time it gets hot ill chexk for shorting wires
Old 10-08-2009, 12:22 AM   #4
tecky11
all right small update, maybe you can help me. i just replaced the alt, get a jump runs for 10-12 min then dies and refuses to start, where do i go fromo here?
Old 10-08-2009, 02:05 AM   #5
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Just a guess; fuel system?
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 10-08-2009, 12:00 PM   #6
OrrieG
OrrieG's Avatar
Check the coil. In the good old days in Phoenix we would see alot of problems when it got really hot with coils heating up and shorting out. When they cooled down they would work fine until they got hot again. Fords were worse than GM but we did see it, especially in big cars with lots of stuff under the hood. Might be another running time related wiring problem, too small guage wire (you said it had been rewired right?), intermintent short or poor connection that only show up when it gets hot. Might be vapor lock or fuel pump not working properly when it gets hot too, I've seen that happen. You should be able to eliminate fuel from the equation by see if its running dry. If its still squirting and not starting then back to electrical, which is frustrating at best. I'm a big fan of the wiggle, ouch that wire is hot, method of initial diagnosis.
Old 10-08-2009, 07:48 PM   #7
tecky11
coil is good, battery is good, alt is new, battery cables are new. then timing chain broke and i can tfind another one!!!!!!
Old 10-08-2009, 08:56 PM   #8
Atomsplitter
Atomsplitter's Avatar
I had a '79-1/2 Toyota Supra that had the same problem with it running for 10 minutes and stopping. The first time it happened the charge light came on and the car died in about 10 minutes. I charged it up....same thing. I replaced the alternator because the charge light was coming. It turns out the rebuilt alternator has a bad regulator, the second alternator also had a bad regulator but the third I tried was perfect. The guy that did the rebuilds was baffled himself as these were brand new regulators out of the "CHINESE" box.
I hope your problem is easier to fix that mine was.
Atomsplitter is offline   Reply With Quote
Old 10-09-2009, 01:56 PM   #9
OrrieG
OrrieG's Avatar
If your altenator had and extenal voltage regulator then they should be replaced as a pair. Same with generators. Hard expensive (relative at the time) lesson I learned as a lad.
Old 10-09-2009, 04:42 PM   #10
tecky11
ok since i cant get a damn timing chain for this thing, will i be able to use a gm I6 with an IH tranny. it currently has an I6 already in it
Old 10-09-2009, 11:30 PM   #11
nickp51chevy
Have you checked with napa?
Had;
Old 10-10-2009, 09:00 PM   #12
mr48chev
mr48chev's Avatar
What engine do you have in the truck?
And now that I think of it is it a Chevy or GMC.
If it has a 235 six in it it has timing gears and no chain
Old 10-10-2009, 09:18 PM   #13
tecky11
bd 240
Old 10-10-2009, 09:55 PM   #14
mr48chev
mr48chev's Avatar
Alright, that isn't helping because I have no idea what a BD 240 is.
You are going to have to give real information.
What make and model is the truck and what exact engine does it have?
Napa shows a 243 six or a 287 V8 in 55 GMC and it would be a 235 six or a 265 V8 for a Chevy.
There is no vehicle shown in your profile and you don't show any in your signature.
You assume that we know what you are taking about but you know what assuming will get a person.
I don't want to sound harsh but if you actually want information you have to provide all the information you can to get that help.
I went hunting and it looks like you have a 1ton or bigger International flatbed. From when I was chasing parts for Ryder Trucks 35 years ago I can safely say that you may as well go straight to the International dealer's parts counter and be very patient. International was very hardcore about not letting aftermarket parts have the designs for many of their parts. That may be the reason you are not able to find the pieces through your normal channels. I ran into that quite a bit either chasing parts for Internationals or when doing repairs on them. Even a lot of their radiator hoses were only available through them.
Old 10-10-2009, 10:49 PM   #15
tecky11
im sorry my bad, i have a 1955 intl truck with a sttraight 6, the timing chain(gears) either broke or came out of time. it is currently backfiring thoroug the carb. it is a 240CID with a 5 speed manual behind it.
Old 10-10-2009, 10:52 PM   #16
dwcsr
Hollister Road Co.
dwcsr's Avatar
One of the IH boards would be better help than here. I'm sure some one there would know where a chain is new or used.
dwcsr is offline   Reply With Quote
