Old 10-04-2009, 12:44 PM   #1
carter442
better gas mileage
i have an 88 k2500 6 lug 3/4 ton. it has a 700r4 and a 350 tbi 3.42 gears. my fuel gauge doesnt work so i estimate my economy at 10 mpg so i dont run out but when i decided to go up a bit to se what im really geting i went to 13 mpg and ran out of gas when i should have had 3 gallons in my truck. i dont rev more than 2000 rpm on acceleration and at cruising at 50 to 55 im reveing about 2100 to 2200. iv seen people with these exact same conditions that are gtting close to 20 mpg i drive 27 to 28 miles a day an only 2 of them are in the city the rest are in the country or highway any ideas why my gas mileage is horrible?
carter442 is offline   Reply With Quote
Old 10-04-2009, 03:15 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: better gas mileage
Lots of things affect fuel mileage, not the least of which is the appointed masher of the gas pedal. Beyond that, it's things like stop and go driving, rapid acceleration and braking, poor engine condition, slipping transmission components, and the list goes on and on.
It could be as simple as a thermostat that is rated at too low a temperature which then allows for a cooler coolant temp that doesn't compute with the electronic inputs to the CPU, and subsequently enriches the air/fuel mixture. A richer mixture is then read by the O2 sensor and that means another adjustment to the fuel system.
It's kinda hard to diagnose like this. Maybe some others will generate a list of stuff to check.
Member Nr. 2770
Old 10-04-2009, 03:25 PM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
If you are twisting that kinda RPM at 55, then your trans is slipping bad or you have really short tires
Or, somebody changed the rear gears
Mine cruises at 65 and 70 at those RPM, and has 3:73s with 29" tall tires
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-04-2009, 03:46 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
At 45MPH, my 3.43 geared V6 is rolling at less than 1500 RPM's. On the highway, 65MPH is less than 2000RPM. The tires I am running are "short" so my speedometer reading is optimistic, too. An indicated 35MPH, is actually 33MPH, per the PoPos' speed monitor strapped to a street sign post.
Member Nr. 2770
Old 10-10-2009, 10:00 PM   #5
brawley
Easy Does It
brawley's Avatar
just my 2 cents..but I changed out my catalytic converter,my old one was getting clogged up, my fuel milage went from 10-11 to 14mpg and this is all in town driving.
brawley is offline   Reply With Quote
