Old 10-04-2009, 10:27 PM   #1
pmj1@mts.net
pmj1@mts.net's Avatar
no spark ??
okay so heres the question ---- 1971 k5 350/ new dizzy/ wires/plugs/ neut switch etc
i turn the ignition to start and it wont fire .... i can hold the key in the start position all day and it wont fire..... but as soon as i let the key go... in the run position she fires and starts up right away wtf ????
azzkikr 1971 chevy K5 Blazer
350/350 .30 over 35"s 4"inch lift custom upholstry
pmj1@mts.net is offline   Reply With Quote
Old 10-05-2009, 12:01 AM   #2
old man jimmy
Re: no spark ??
First guess would be the ingnition switch itself. Have you checked to see if you're getting fire at the plugs when it's cranking?
old man jimmy is offline   Reply With Quote
Old 10-05-2009, 06:50 AM   #3
vtblazer
vtblazer's Avatar
Re: no spark ??
Wires on the solenoid switched?
Something about start power vs. run power between the two small wires.
vtblazer is offline   Reply With Quote
Old 10-05-2009, 12:34 PM   #4
truckster
truckster's Avatar
Re: no spark ??
I'd check the "R" and "S" posts on the starter solenoid.
truckster is offline   Reply With Quote
Old 10-05-2009, 06:24 PM   #5
pmj1@mts.net
Re: no spark ??
thanks for the info guys heres what i've found only 2 wires hooked up battery and purple ignition what color is the third wire supposed to be ??
anybody?
Old 10-06-2009, 01:43 PM   #6
pmj1@mts.net
Re: no spark ??
problem solved !!! when i changed out the dizzy to the msd type i ran a heavier gauge power wire but unintenionally hooked it up to the radio terminal on the fusebox this wire has to be hooked up to the unfused 12 volt terminal or youll have these stupid problems thanks for your input guys !!!
