Old 10-05-2009, 11:53 AM   #1
halfcockedcustoms
halfcockedcustoms's Avatar
lowering block ?s
Is there any place other than cpp that sells lowering blocks for my 64,,it has 3 in springs already but its just not low enough,,I dont have the tools to make my own,,just wondering if anyone else sells them
halfcockedcustoms is offline   Reply With Quote
Old 10-05-2009, 11:55 AM   #2
Boomerswany
Retiredoldfarttankerguy
Boomerswany's Avatar
Re: lowering block ?s
The Filling Station, they've got 1 1/2 and 2"...
________________________________
Swany
Current 67-72 truck projo - #5 of 6 and #1,000,000... of all the other things that keep me from working on it.
Fav - local parts shop. They ship world-wide. www.fillingstation.com
Boomerswany is offline   Reply With Quote
Old 10-05-2009, 11:58 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Make your own !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-05-2009, 12:21 PM   #4
xratt
xratt's Avatar
I plan on making my own. Some 2inch square stock, drill a couple of holes. done!
1966 C10, SB305, bagged.
1955 VW Buggy, 2.0L
1978 Honda CB550
http://67-72chevytrucks.com/vboard/s...9&goto=newpost
xratt is offline   Reply With Quote
Old 10-05-2009, 01:00 PM   #5
terd ferguson
terd ferguson's Avatar
I used 3" square tubing. It's really pretty easy. All you need is the tubing, a cut off wheel, and a drill bit. You can get a cheap harbor freight grinder and a pack of cut off wheels for less than $20. You'll be in it cheaper than buying pre made blocks and you can do it yourself. Most folks have drills, I assume you do to. But if you don't, they're just as cheap.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson
1955 2nd Series Chevy "King Of Trucks"
terd ferguson is offline   Reply With Quote
Old 10-05-2009, 01:31 PM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
usually at a metal dealer you can get the metal , and they will cut it for you to whatever length you need
I would say, get 2X2X6X1/4 inch thick.
Old 10-05-2009, 02:33 PM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: lowering block ?s
Lowering block kit
http://www.autozone.com/autozone/cat...questid=218372
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 10-05-2009, 04:59 PM   #8
terd ferguson
Originally Posted by 1Bad62Pro/Street View Post
Auto Zone DOES NOT stock Ubolts that are the correct size. The Ubolts look very close to the right size, but no matter how much banging around you do with a hammer, they WILL NOT FIT. Don't spend $30 for an aggravating afternoon. Don't ask me how I know, lol.
I had some Ubolts custom made at a big truck shop. I took a stock Ubolt there and told them I wanted them 3" longer. They bent them and threaded them while I waited. It took about 15 minutes and cost $40. They came with nuts and washers.
Old 10-06-2009, 10:10 AM   #9
1Bad62Pro/Street
The 2" U-Bolt lowering block kit worked fine for me. But I have a Ford 9" rear end.
Old 10-06-2009, 10:15 AM   #10
halfcockedcustoms
most of these trucks have trailing arms not leaf springs,,,
Old 10-06-2009, 11:55 AM   #11
1Bad62Pro/Street
Talking Re: lowering block ?s
Yep...
I guess what I should of mentioned is that it worked fine in my application.
Which is not stock at all.
My frame has been altered alot.
Ha ha.....
Well I was no help at all was I?
Sorry fellas.
I'll take a beating!
Old 10-06-2009, 01:37 PM   #12
terd ferguson
I should've said they don't work with stock rear ends.
Old 10-06-2009, 01:38 PM   #13
terd ferguson
You can use blocks with trailing arms. I did.
Old 10-06-2009, 02:46 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I wrote an FAQ article about making your own lowering blocks. If you care to read it, it's in the FAQ section. Lots of pictures.
Another easy way to make some blocks is to just cut the rear sections off of old trailing arms. Pre-made lowering blocks !
