Some help please....heat defrost cables..
Searched and couldn't find anything on this, my heater/ defrost cables are very difficult to move, and will actually move back after sliding the lever either way. Any advise on how to lubricate the cables, and best way to introduce the lubricant to the cables? Thanks......
1967 GMC 3/4 ton Fleetside 350 ci Chevy I'd rather do it myself and spend the extra 500 dollars |
Redefining LowBudget
Re: Some help please....heat defrost cables..
subscibed
best I have done is used motorcycle cable lube ..sprayed some in the control panel ( used the little tub thingy) and on the working ends of the cables..seemed to help some but stilll not smooth so I'm open to other ideas |
I am a Referee of life.
I took mine out while doing an oil change.Then I laid them in a parts washer for a day.After that they went into the drain pan of used oil.I actually forgot them for a few days.Then I used a vise and pliers to make sure they moved freely.They have been back in the truck for about 9-10 years and still work perfectly.
If you haven't rebuilt the controls it's a good idea.The original levers were of pot metal and break easily while the rebuild kits use steel and are much stronger.Most BB vendors will have the kit(about$20-30 IIRC)
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 10-05-2009 at 07:25 PM. |
Active Member
![]() Join Date: Jul 2007
Yeah, take them off and lube them with penetrating oil. On my 68 the have a rubberized exterior and I used spray oil to free them. They're still a little tight but work good.
Thanks!
