spindles
does anybody know if any companies still make/sell lifted spindles for 73-87 c-10 2wheel dr. ? also same for 3/4 ton same years Thanks. art
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
6.0 powered square
Re: spindles
there isn't, I think threes a way to use a 88-98 lift spindles with a ball joint change but most that lift 73 to 87 2wds use big block or 1 ton coils or if they can find lifting springs which is hard to come by and they did make lifting control arm but they caused a few problems, and there's also a body lift, I build a truck for a friend that had big block springs and 3" body lift and its a little higher than a stock 4wd
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 10-05-2009 at 05:24 PM. |
