Old 10-05-2009, 05:25 PM   #1
Patriot
1979 1 Ton frame?
Hello fellas, I'm new to the site but not new to turning wrenches. I have a question for you 73-87 wizards. I just bought one of my dream trucks and it served as a tow truck in its past life. It is a 1 Ton Dualy 4X4. I need to know if there is a difference in the 3/4 ton frames. The frame has been cut(torched) and all kinds of crap welded to the frame. I use to run a weld/machine shop and graduated from an Autobody class and had my own Autobody business for a while before getting called out for this war so working on or restoring a truck is second nature to me. I just can't seem to find any info(frame dimensions) on these trucks on the internet or in my books.
Thanks fellas in advance.
Patriot
Patriot is offline   Reply With Quote
Old 10-05-2009, 05:56 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: 1979 1 Ton frame?
I think there's a little difference but not much
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-05-2009, 05:59 PM   #3
Patriot
Thanks. I heard that there is a difference in the size of the frame i.e. 1/2, 3/4 are 6 inches and 1 ton is 8 inches. Not sure if this true. My 79 measures out at 8 inches.
Old 10-07-2009, 02:58 AM   #4
BIG V
the 1 ton frame is taller, and thicker materal if you can wait till this weekend ill be at the ranch and ill get some pics
BIG V is offline   Reply With Quote
