10-05-2009, 10:07 PM | #1 |
Wheelin' and Dealin'
LT1/4L60 SWAP into the 65
has this been done by anyone on here, a few pictures and a good idea of what has to be changed would be great, my previous drive train is 400/th 350
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears 1BADD65 my build thread: http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
10-05-2009, 11:39 PM | #2 |
Re: LT1/4L60 SWAP into the 65
im in the process now not to bad of an install i have left the turbo 350 in for now will change it after i get any bugs worked out the last thing i have left is a fuel system and then hope my wiring is ok of you have any questions let me know i will try to get some pics up of it
10-06-2009, 01:33 AM | #3 |
60-66 Nut
Asside from the wiring for the injection and the trans, and the plumbing for the injection, it isn't much different than your previous engine. One thing about the LT1/LT4's is they have a reverse cooling system in the block and heads as compared to a standard small block. I'm not sure if that requires a different configuration radiator or not. Might be something to check into.
*Edit* one more thing, the trans will have a electronic speed sensor that needs to be there for the ECM to read, but that doesn't give you the needed drive for a mechanical speedo. I believe there is an adapter of some sort to give you a mechanical drive as well as the electric signal.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-06-2009 at 01:38 AM. |
10-06-2009, 12:12 PM | #4 |
Word of advice, don't ever get water on the optispark, it is an expensive fix! So no washing your engine with water or anything like that. If you need to do anything with the water pump or thermostat housing, drain everything really really really good. I can't stress this enough, these optisparks are extremely water intrusion prone.
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
10-07-2009, 10:43 AM | #5 |
What are you guys using for a throttle cable? Did you go aftermarket or actually bend up a long rod for the linkage?
10-07-2009, 05:05 PM | #6 |
check out www.lt1swap.com there is alot of good info
I love the smell of lead paint! |
09-17-2010, 01:45 AM | #7 | |
09-17-2010, 09:29 AM | #8 |
It is not that hard to do but if you are on a budget it is a little more difficult. You need to get the entire wiring harness and ecem from the donor car. I built my own harness as they wanted around 900.00 for them, to do this you need the wiring manual from the car the motor came from. Throttle cable is from Lokar as is the kickdown cable.
09-17-2010, 10:37 AM | #9 |
Slots go on anything!
The LT1 was already installed in my old '79 when I got it, but I went through a good bit of it. They used a Painless harness, which seemed to work well. Painless offers a VATS bypass module, which was used in my install. The VSS will work to control the computer, but you will need to get an adapter to run your speedo in the dash. JTR has a few solutions on their website, or you can get a cable-x box. Herron Performance had a deal on them recently. Mine used a Lokar throttle cable as well. It is a great swap, IMO, but I would want to run the 4L60E over a TH350.
1974 Jimmy- 5.3/4L80e/NP241 |
09-17-2010, 01:48 PM | #10 | |
09-17-2010, 03:06 PM | #11 |
If you are sending the ECEM off to get reprogrammed than you should know what you need out of the wiring. For example, you want to get rid of the VATS, the evap sensor, 2 of the O2 sensors etc. , Hey BTW Dave , this motor came out of a car in Maple Ridge, I was just at the A&W cruise there 2 weeks ago with my truck.
09-18-2010, 07:03 PM | #12 |
I am in the early stages of putting an LT1/4l60e in my 65 SWB. I bought a donor car,a 95 Buick Roadmaster, for all the new parts. I had an LT1/2004r in the truck previously for a short period so some of the new swap is already done. I'll build my own harness from the one in the Roadmaster. As for accelerator linkage,I used the stock LT1 cable and modified inside the cab to use the pedal from a blazer(could use probably any gm pedal made for a cable linkaga). Cost nothing and worked really slick. Currently,I'm stripping the Roadmaster and hope to pull the drivetrain next weekend.
11-23-2010, 01:55 AM | #13 |
Im doing this swap now in my 65. had lt1350.com do my harness and comp program with other ecm tuning and trans tune. total cost with the harness extend to get the ecm by the glove boax was 575. well worth it I think. they have a complete wiring diagram on the web site so you can build your own harness. also keep in mind your fuel pump. you will need to run new fuel lines with a return line and a fuel pump that does 45psi min. the pump I used is made by professional products part number 70151. I got it from No limits speed shop in stockton, Ca for $160
1965 c20 converted to a 1/2 ton with lt1/4l60e, 12 bolt, disk, ac, lots of little mods 1964 c10 ratrod project going diesel 1970 f100 in the process of getting a powerstroke from a rolled 2007 f350 1972 International travelall. frame off resto for the wife 1969 International with chevy 350 700r4 the list never ends! |
02-01-2011, 08:16 AM | #14 |
I have dropped an LT1 I converted to carb in my 64 and was wondering what you guys did for the cooling system? I don't have the donor car anymore or the radiator from it and I was going to try to use the radiator from the 64. Sooo I guess what I am asking is does anyone know if I can just run a line across the back of the head and if I can just cap the small port on the water pump on the driver side or do they all need to run to the radiator as they did in the z28? Any help would be great.
08-08-2012, 10:54 PM | #15 |
I am interested in the cooling system as well. I am getting ready to perform this swap myself. Any info you guys could give on the cooling system, anything strange?
65 short step edited by staff |
08-09-2012, 10:07 AM | #16 |
My LT1 conversion is now on the road and the cooling worked out quite simple. Stock radiator with a universal coolant recovery system and tie the steam pipe from the back of the heads into the heater hose near the water pump. This setup runs cool and purges the air from the system.
08-11-2012, 03:41 PM | #17 | |
The bypass hose I went from the head to the neck of the water pump just drill into alum. neck of pump and tap it to pipe thread to install 90 deg hose fitting it was nice and tidy. Hope this helps. |
08-12-2012, 02:40 PM | #18 | |
08-14-2012, 01:47 AM | #19 |
I can e-mail you pics. if you want send me your e-mail mine is dsaddler@comtruck.ca
08-29-2012, 12:01 AM | #20 |
dave69 whay car was the water pump for?
08-29-2012, 08:12 AM | #21 | |
66 LWB/BBW work in progress 68 Camaro SS bigger work in progress 95 Roadmaster Wagon 12.36 @ 107.74 99 Hayabusa 8.72 @ 162 00 Hayabusa 9.33 @ 153 |
09-22-2012, 03:41 PM | #22 |
LT1 Burb, engine looks awesome in there. What did you do for fuel lines? Mine are on the drivers side and stick up in and look like c@#p. Thanks
09-23-2012, 09:31 AM | #23 |
Mine were too but there is a company called street and performance in Mena Arkansas that sell a kit to get it to the frame rails. From there I would advise to go to aluminum to the tank. I had all these lines done in Russell steel braid the first time and they leaked through, to the point my whole frame was wet with gas. I had to move it out of my garage because of the smell.
09-23-2012, 09:36 AM | #24 |
Updated with air pics.
09-23-2012, 09:58 AM | #25 | |
Tim. Posted via Mobile Device
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
