10-06-2009, 12:08 AM | #1 |
84 Front suspension complete
I just recently removed my entire front suspension and steering components. My 1984 GMC truck has less than 4000 miles on it since the first build in 1991. So the brakes are in great shape pads are thick. This truck has never been stored outside it has always been in a garage. I'm selling the entire front suspension setup; cross member, spring buckets, springs, upper and lower control arms, motor mounts, sway bar, steering box and all linkage. My truck was built with the Camaro / Corvette bolt pattern 5x4.75" the rotors are 5x5" bolt pattern that were drilled to 5x4.75" so they could easily go back to 5x5. The ball joints and rubber bushings were all replaced at the time of the build and are in great shape, the rubber is not cracked. Truck frame sat 5" from the ground. Asking $500 obo.
Please email me or call with any questions. 602-740-6374
Ryan 84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
