progress and questions
i got the cab off today and got my nos a-arms along with my drop springs. i also got my blazer gas tank in the mail,i was wondering does any one have pics of the installation? and or directions for me ? one more ting what are all the vent fittings for theres a couple. thanks everybody
1986 c-10 swb 5/7 drop 20'' coys 1958 belair 2door |
Almost Satisfied
![]() Join Date: Mar 2002
I think Wes has gas tank install directions on his web page. www.classicheartbeat.com
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
tank
sending unit
last
no one? i know lots of people have blazer tanks
someday
![]() Join Date: Dec 2001
I am just wondering where you are in ney york because i dont see snow in those pics and when i look out the window i see plenty of the s#*t.
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
The little vent next to the filler neck is for the filler tube vent. The one next to it is for the tank vent. You run a vent line with a brass filter up into the frame rail. The one on the other side of the tank is for the charcole cannister that sits up in the top front right corner of the truck, on the inside of the fender. As to installing the fuel sending unit, the easiest way to install it is to remove the metal ring on the tank first. BE SHURE THAT THE TOP SIDE REMAINS THE TOP SIDE.... Mark it if you have to. Then set the rubber "O" ring in the recessed spot that would be under the sending unit. Befor you set the sending unit in, I bend the grounding tab in about a 30deg. angle, then bend the part that the connector pushes onto in another 30 degrees. This will help with the instalation to follow. Slip the sending unit into the tank with the feed tube facing the filler side of the tank. The tube will look align with the groove molded in the tank under it. Then feed the lock ring over the sending unit untill it rests on top of it flat. Then you take the ring whitch you removed in the beginning, feed it on top of the whole works, and screw it back in place after you possition the lock ring with the little tabs next to the little protrusions on the top ring. Here is a picture of the sending unit installed. It is awfull small but it is as large as I can get it on this board. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 10-04-2007 at 06:47 PM. |
Pick'n up the pieces!
special70gmc,
If you could, I would like to know what the dimemsions of a blazer tank is? Thanks, Danny |
ill check the dementions tonight, one more ? WES the straps that come with the tank do you happen to have a pic or anythin to show me how to bed them? -thanks
26 x 161/2 x 14 its got alot of indintations and its not totallty square but thats close, sorry i coulnn to any better
found this link i think it will be very helpful to me and any one else who has this tank http://www.low69cst.freeservers.com/Blazertank.htm
#13 |
Hey thanks for the dimensions! Still head scratchin' in Ok. Danny
